10-11-05, 10:02
mark2003 is offline
Join Date: Oct 2002 Location: B.C. Canada Posts: 96 | Couple of question about applying polish/wax with PC Im going to be using a PC for the first time pretty soon. I'll be putting on Z-PC followed by Z-2...Now im wondering how the procedure actually goes.
Do you work the Z-PC in till its all almost worked itself right into the paint, and then buff the remains with a cloth, or are you supposed to stop and buff off when its more of a haze?
Do you work a couple of feet of the car at a time, or should you go ahead and do the whole panel at once when using Z-PC?
Silver 93' Honda Prelude SR
10-12-05, 03:45
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,881 | I haven't used Z-PC myself, but if it's just like a typical polish, you'd work it until it's nearly clear. Until you can barely see it on the paint anymore. Buff it off right away after you're done working it.
Yes, work a couple square feet at a time. And be patient, move slow. The PC takes a while to break down polishes. Don't be afraid to use speed 6.
__________________ Paul...
10-12-05, 03:51
| | No prep, no pride!
a.k.a. Patrick is offline
Join Date: Mar 2004 Location: Thousand Oaks, Ca Posts: 4,516 | Agreed.....I opt for applying no additional pressure to the PC either, accept to manipulate its movement. I feel its plenty heavy on its own....Porter cable doesnt even recommend using additional pressure. (Im not sure if some of you other users are aware of this).
__________________ Owner Excel Detail & Car Care Products. Just an enthusiastic detailer, providing professional services.
You-Dee-M'er... | |
10-13-05, 04:14
flatstick is offline
Originally Posted by a.k.a. Patrick Agreed.....I opt for applying no additional pressure to the PC either, accept to manipulate its movement. I feel its plenty heavy on its own....Porter cable doesnt even recommend using additional pressure. (Im not sure if some of you other users are aware of this). |
I have used the ZPC and I feel it is very user friendly, does dust quick similar to SSR2.5 but it does leave a very nice smooth finish to start the Z process. just remember to do a Z6 wipedown after you are happy with the ZPC finish on the whole car. I have to admit the no or very little ( for some scatches only) pressure approach has worked for me, maybe because I do not have too many very bad cases that I am working with. it just worries me to hear everbody using pressure all the time even for just lsp removal or applying over the entire car . the way I look at it you only have on cc. the Autopian motto is always use the least aggressive products/ pad combo you can get away with, some defects are just to deep to remove. I have read the article by Meguiars stating that you need to use pressure and it makes sense but 5-6 lbs all the time ? 20 lbs seems like a lot. yes the scratches are removed but if you do not have a paint thickness gauge to see where you started and where you are at how do you know how much cc is left ? guess I like to err on the side of caution. I would like to see people chime in to see their views as well. sorry did not try to hijack this thread | |
10-13-05, 02:22
mark2003 is offline
Join Date: Oct 2002 Location: B.C. Canada Posts: 96 | Thanks for the help
Another question...what do you guys do around those parts of the car where the whole pad is unable to be on the surface of the paint? Looking at my car, there are edges and such where it just wont be possible without only have like half of the pad touching the car. Do you just do those parts by hand?
10-13-05, 02:30
Black240SX is offline
Join Date: Oct 2004 Location: Victoria, Canada Posts: 576 | It's ok to have only part of the pad in contact with the surface. Just be sure and reduce the pressure applied to compensate for the smaller contact area.
A well-prepared surface will make any wax look good.
10-13-05, 02:58
mark2003 is offline
Join Date: Oct 2002 Location: B.C. Canada Posts: 96 | Quote: |
Originally Posted by Black240SX It's ok to have only part of the pad in contact with the surface. Just be sure and reduce the pressure applied to compensate for the smaller contact area. | Is there a certain speed to run before polish is going to start spraying at me from the part of the pad thats not touching?
10-13-05, 03:03
Join Date: Oct 2004 Location: Victoria, Canada Posts: 576 | Oh yeah, it helps to reduce the speed by one or two settings. If possible, start the polisher in an open section, and then move into the narrow area. With a little practice, you shouldn't have any splatter.
10-13-05, 05:04
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,881 | It may also help to get some 4" pads and a 2.25" backing plate for the PC. It allows you to get into smaller areas pretty well.
Some areas you have to do by hand. There's no way around it.
10-13-05, 06:09
3Dog is offline
Join Date: May 2004 Location: Nashville, TN Posts: 1,133 | Quote: |
Originally Posted by White95Max It may also help to get some 4" pads and a 2.25" backing plate for the PC. It allows you to get into smaller areas pretty well.
Some areas you have to do by hand. There's no way around it. | Where have you found 2.25" plates? I have some 3" but smaller would be great.
Ric
3Dog Garage
HOGtailing is my business
10-14-05, 06:20
| | Administrator
DavidB is online now Join Date: Mar 2001 Location: Autopia... Where else! Posts: 6,392 | Quote: |
Originally Posted by a.k.a. Patrick Agreed.....I opt for applying no additional pressure to the PC either, accept to manipulate its movement. I feel its plenty heavy on its own....Porter cable doesnt even recommend using additional pressure. (Im not sure if some of you other users are aware of this). | Patrick,
Porter Cable's perspective comes from using the PC as a sander, not an automotive polisher.
Regardless of how Porter Cable designed the machine to be used, anyone using the PC as a serious tool to polish paint applies pressure. It's necessary to apply pressure in order to get enough friction to heat a cutting polish so that the abrasives will break down and polish out.
I agree that a "paint cleaner" polish like Z-PC does not require much friction to do its job, which is why it also works by hand.
db
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 02:53. | | | |
