gadsan brings up a good point - your pad might be dirty? Optimum polish isn't a very aggressive polish, even on a cutting pads it's probably only the equivilant of SSR2, so if you're seeing hazing it might be more the pad at work than the polish - perhaps you weren't using enough product? I tend to use a little more optimum per panel than SSR. Just a thought. Either way, give the optimum and the green pad another go, just move nice and slow. If that still doesn't do it try the 2.5.
