Originally Posted by dschribs For those of you that use Propel pads - how often do you break out the orange pad? Can I get by with just using thier yellow pad and maybe using a slightly more aggressive polish (such as Meg's #83) ? Is the orange pad really something that I would need in detailing friends/neigbors cars that are not in really bad shape ?
I currently using Meg's polishing pads and I'm looking for something that's a step up from those for slightly more heavy duty swirl/scratch removal. Would the Propel yellow be the way to go? |
Why don't you email or PM Patrick? I'm sure he'd be happy to help.
I have the green and yellow Propel pads, didn't get the orange as Patrick said I didn't want to go near it unless I had some serious paint correction. I didn't, so I didn't order it.
I can also say that the Propel yellow pad can be messy to use until you get the hang of it. I emailed Patrick about a messy clean-up after using Megs #83 and the yellow pad, and he said that the open pore structure (which allows the pad to cut) doesn't allow much in the way of "holding" product. He said that you have to add a little at a time until the pad's fairly well seasoned. That and keep the initial PC speed low, like around 4. Once the pad's seasoned, the PC can be turned up.
I think I'm going to try to do the most of my polishing from now on with the green Propel.
