Okay... Well again I didn't have much time but I thought I would give it a go. Went at it with the
Sonus SFX Orange pad and SSR2.5 with more pressure and had the PC set on 5.5, then SSR2.5 on a Green DAS pad worked at a 5 setting on the PC, SSR1 on a Blue Sonus DAS pad worked at 5 on the PC, RMG with black LC pad worked at 5 on PC and rather quickly(waited 30 minutes) removed with yellow sonus microfiber bonnet used at 3.5 on PC and topped it with
Souveran which I removed with a white Sonus microfiber bonnet set at 3.5 on the PC and followed up with a fluffy Pakshak microfiber and 4* QD. I can definetly see the improvement, actually it is nite and day but it is still far from perfect. I think that with a little more practice and better light I will be able to get it all out. BTW I never had a chance to get the halogen lights tonite and I was working with nothing but one of thoes little hand held flourecent lights. I also ordered some SSR3 today so I will use that for the heavier scratches. Here are 2 photos. Thanks again for all your help, more opinions or advise VERY wellcome.
Before
After
