06-10-05, 02:39
UnsanePyro is offline
Join Date: Sep 2004 Location: Rhode Island Posts: 364 | Can't get rid of the swirls It's a 1997 Acura 2.5 TL (Honda if you aren't framiliar).
I just can't seem to get a swirl free finish with the PC.
I've got Lake Coutny (I believe, not sure off the top of my head) pads. Black, blue, green, yellow, orange.
I decided to give the SSR that I just got a try today, since I was really impressed with the Natty's Paste.
SSR2 with a green pad didn't do anything for the swirling.
Another pass also left no noticable effect on the swirls.
I did both those passes at speeds from 4 to 5. I did notice a definately change to the color of the paint though, it seemed to be a bit darker than when I started. It's green with some flake to it.
Since neither of those worked, I bumped up to a yellow pad, SSR2 again, speed around 4.5-5 most of the time. This didn't do anything for the swirling either. I did get some very light hologramming though.
I'm not quite sure where this leaves me.
The pads are clean, towels are clean, car was clean. I worked the SSR2 until it began dusting, and then removed. I put some SSR2 on the pad, smeared a bit on the car to begin with, and went at it, up/down, left/right, and diagonal. I used a decent amount of pressure, firm, but not enough to bog down the PC.
Anyone know whats up? | |
06-10-05, 02:42
| | Stop being so dramatic.
MongooseGA is offline
Join Date: May 2004 Location: Virginia Beach, VA Posts: 1,991 | Try a rotary
Good luck
-G.A. Jr.
06-10-05, 02:44
Join Date: Sep 2004 Location: Rhode Island Posts: 364 | Haha, I worry that if I can't seem to do much with a PC, that a rotary may be too much for me. The whole idea of burning paint sort of worries me a bit. | |
06-10-05, 02:52
| | Super Moderator
JDookie is offline
Join Date: Dec 2002 Location: USA Posts: 4,095 | Don't give up just yet. There's still more the PC has to offer you. SSR2 isn't the most aggressive polish to be working on a hard clear with. It sounds like your process is correct, you just need a stronger polish, and maybe a more aggressive pad.
You mentioned black, blue, green, orange, and yellow pads. This sounds like Propel pads to me. Where did you get them from? What's on the back of them, if anything?
Next, how big of an area were you polishing at a time? You were correct in polishing until it dusted, but if you polished too big of an area, the product flashed too quickly and you weren't actually doing much in the way of polishing.
Before I go any farther, let's start off here. | |
06-10-05, 02:54
| | Banned
Burlyq is offline
Join Date: Nov 2004 Location: cali Posts: 1,445 | Increase RPM's to 6, when using a finishing polish kick it down a notch. | |
06-10-05, 02:59
Join Date: Sep 2004 Location: Rhode Island Posts: 364 | JDookie: Yup, thats right, Propel is what I have, for some reason LC just seemed to be what came to mind.
I was hoping that the SSR2 would be enough, but I may pick up some SSR2.5 and SSR3, I have been really impressed by the poorboys line in general so far.
I didn't think of the the product flashing too soon, I would put it on the pad, spread it over half a door (top half), and then work half of that half (so 1/4 of a door) and then the other side. That could very well be were my problem was, letting the product sit too long without being touched.
I'll have to give it a try Sunady, tonight the sun is down, tomorrow is my HS graduation, and I think Sunday will be the first bit of free time I have. | |
06-10-05, 03:01
| | Super Moderator
JDookie is offline
Join Date: Dec 2002 Location: USA Posts: 4,095 | Sounds like you are already figuring it out on your own. That's exactly what I was going to suggest. Get a stronger polish, and work it longer, in smaller areas.
Also, try to polish on a higher speed. I like speed 5, with an occasional 6. Speed 6 seems to tear up the pads a bit, so I tend to stay on 5 most of the time.
FYI, if you ever want to get a step closer to a rotary without the dangers of a rotary, try out a Cyclo. After using one, you won't go back to the PC for heavy polishing work anymore.  | |
06-10-05, 03:06
| | Buy silver or gold cars
tdekany is online now Join Date: May 2004 Location: Fairfax Virginia Posts: 6,127 | I have never been able to remove swirls with ssr 2 - Minimum a ssr 2.5 is what's needed. (mho) Orange (light cutting pad & SSR2.5 is an excelent combo.
__________________ New Shine Detailing - Mobile Service | |
06-10-05, 03:12
| | I drive a station wagon!
J.J. is offline
Join Date: Mar 2005 Location: OH Posts: 1,125 | I was able to try the cyclo this week. I was actually impressed with the machine and the work it does however, for the money, I would go with a rotary. The rotary is not as intimidating as everyone makes it out to be. I wish I would've bought the Makita instead of my PC. Although, I would have eventually bough a PC anyway b/c it's such a great tool.
I just realized I contributed nothing to this thread... sorry!
JJ
__________________ MZ3 Hatch Zoom - Zoom | |
06-10-05, 03:14
Join Date: Sep 2004 Location: Rhode Island Posts: 364 | I have some other polishes that I may try out. I have some Einzett polishes (strongest/medium, but not the light) and a very limited amount of SSR2.5.
I usually start out around 3.5-4, but end up working 4-5, I don't like 6 because it just seems like it wants to cause trouble with the little PC.
Whats the deal with the cyclo? Could you point me towards any more info off the top of your head? I'll search for it later on but the right direction would be cool.
TD: Thanks for the insight on what works for you, its always helpful. I'll give it a try if I get a chance to pick up some SSR2.5 | |
06-10-05, 03:15
newagain is offline
Join Date: Aug 2003 Posts: 269 | No disrespect, But take it to a professional detailer in your area and asked for some professional advise, An PC will NOT remove SEVERE swirls. | |
06-10-05, 03:17
tdekany is online now Join Date: May 2004 Location: Fairfax Virginia Posts: 6,127 | Quote: Originally posted by UnsanePyro
TD: Thanks for the insight on what works for you, its always helpful. I'll give it a try if I get a chance to pick up some SSR2.5 | You are welcome
PS: I always use speed 6 when doing paint correction. For me speed 4 or 5 is useless. Sorry.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:28. | | | |
