Autopia.org
Old 05-26-05, 04:41   #1 (permalink)
silkman is offline
silkman is on a distinguished road
Makita 9227 + Pads
Hi all,
I'm into detailing some time now and been reading Autopia alot.
After purchasing a PC kit (PC+Sonus pads) from autopia, I can't say that am too happy with it.
I've given it about 3 weekends' work and it appears that too much time is needed for it to work (for scratches and swirls removal) so I'm going for a rotary - the Makita 9227.
It's too much hassle to order again an 110v version (since I need a bigger 220v transformer), so i'm going to get it locally for about 290€ (=$365 )
Here are my questions re the Makita:
I have about 10 pads for the PC (sonus DAS and LC) - I think they're 6" and i don't want to buy more for the Makita. Do I need an extra flex plate and will it work with 6" pads?
What is the recommended pad size for the Makita? I think it's 7.5". I'm using my existing 6" pads, should I be extra careful, will it cut less, more or the same?
Thanks!
Old 05-26-05, 05:51   #2 (permalink)
Tanat198 is offline
Tanat198 is on a distinguished road
Your 6 inch pads are fine. You'll need a new backing plate to go with rotary since it's different from PC.
I started with Makita rotary. However, i need to use PC to eliminate holograms left from using rotary anyway. But if you really wanna try rotary, you should find a junk hood to work with first. Or find someone who is willing to have you tested your skills on the hood. STart with slow speed to get a feel of it. Enjoy and good luck
Old 05-26-05, 06:03   #3 (permalink)
numa numa...
merci is offline
merci is on a distinguished road
The backing plate on the PC will not fit the Makita. Since you're going to use 6-inch pads, make sure you get a 5-inch backing plate.
6-inch pads are fine. The smaller the pads, the more aggressive they can be so make sure you adjust the speed accordingly.
Are you sure they're not 6.5-inch pads?
Resistance is futile. You will be assimilated.
Old 05-26-05, 10:00   #4 (permalink)
silkman is offline
Maybe they are 6.5" not sure - bought them from Autopia as a set with the PC.
Thanks for the info, BTW!
Old 05-26-05, 10:30   #5 (permalink)
MS22 is offline
MS22 is on a distinguished road
I prefer the 6.5" Megs pads for rotary use.
Old 05-27-05, 02:37   #6 (permalink)
dpeezy415's Avatar
dpeezy415 is offline
dpeezy415 is on a distinguished road
I use my PC pads for the rotary. I bought my 5" backing plate at Autogeek. Only place I could find one...
The happiness of a man in this life does not consist in the absence but in the mastery of his passions.
-Alfred Lord Tennyson (1809 - 1892)
Old 05-27-05, 02:39   #7 (permalink)
~werd to yo mutha~
Way2SSlow is offline
Way2SSlow is on a distinguished road
Send a message via AIM to Way2SSlow Send a message via Yahoo to Way2SSlow
Recently began using the Lake Country Tufted pads. I really like them. I think they're 7 inch(?)..or maybe it's a 7inch backing plate.....I'll have to check.
94 Impala SS in the ONLY color
04 Ford Focus ZX3 in white (daily driver)
~werd to yo mutha~
Wade-----Gallery
Old 06-12-05, 06:01   #8 (permalink)
Autopia Master Trooper
PrinzII's Avatar
PrinzII is offline
PrinzII is on a distinguished road
Send a message via ICQ to PrinzII Send a message via AIM to PrinzII Send a message via Yahoo to PrinzII
I have used the 3M pads, Sonus DAS, and Edge pads on a 9227. However, I echo everyone else's sentiment in that you should get a smaller backing plate when using the Sonus DAS pads because they can be very hard to remove from a larger backing plate.
Shift_Cactus!
