05-24-05, 09:06
| | numa numa...
merci is offline
Join Date: Jan 2005 Location: Planet Autopia! Posts: 460 | Makita 9227C spindle disassembly I wanted to replace the spindle of my Makita 9227C with one that has a thread size of 5/8"-11 UNC. Mine is M16x2.
I got the new spindle (labeled #50 in the schematic below) from toolpartsdirect.com but I got stuck trying to remove the old spindle from the assembly.
Check out the schematic here.
Attached are pics of what I'm trying to disassemble.
I can't get to the retaining ring (labeled #46 in the schematic) which I believe is the only thing standing in my way.
Any ideas?
Resistance is futile. You will be assimilated.
05-24-05, 09:15
| | numa numa...
merci is offline
Join Date: Jan 2005 Location: Planet Autopia! Posts: 460 | Side view:
I can't see the retaining ring no matter how hard I look. Can this be disassembled at all?
05-24-05, 02:11
Beercan31 is offline
Join Date: May 2004 Location: NJ Posts: 56 | Seems to me you will need to get a gear puller and pull the gear off the spindle shaft, Be careful not to bur the end of the shaft, it looks like it may slip in to a bearing or a bushing up in the head assembly. Then the snap ring will be exposed fur removal.
good luck.
Rich
I'm going as fast as I can, You want to go faster GET OUT and PUSH.
05-24-05, 02:16
| | Banned
Burlyq is offline
Join Date: Nov 2004 Location: cali Posts: 1,445 | Just curious, why did you want to change the spindle? | |
05-24-05, 03:11
BenP is offline
Join Date: Feb 2005 Location: UK Posts: 794 | Quote: Originally posted by Burlyq Just curious, why did you want to change the spindle? | I imagine for the same reasons I'm condiering changing the spindle if I buy a UK 9227 (which comes with an M14 spindle), and that is that there are far more backing plate etc options for a 5/8" spindle than there are for either the M14 or M16 spindle.
This is the reason I'm considering importing a US 9227, instead of buying one here in the UK.
Ben | |
05-24-05, 06:25
| | numa numa...
merci is offline
Join Date: Jan 2005 Location: Planet Autopia! Posts: 460 | BenP answered your question for me.
BenP, you can actually modify it without removing the spindle - just buy the parts to make a new assembly:
#45 226744-6 SPIRAL BEVEL GEAR 52
#46 962151-6 RETAINING RING R-32
#47 211106-1 B. BEARING 6201LLB
#48 316896-2 HOUSING W/O BEARING
#50 152552-8 SPINDLE COMPLETE
Total cost (no shipping yet): USD70.03
I can actually use 5/8"-11 UNC backing plates but only the first two threads of the spindle are holding it together. It seems dangerous but I've never had a backing plate unscrew and fly on me yet even at maximum speed (3000rpm spin cycle to remove excess water from pads).
05-25-05, 01:32
zey is offline
Join Date: Nov 2001 Location: Kuala Lumpur, Malaysia Posts: 296 | Merci, I am using a Makita 9227C with M16X2 thread size. My Meguiar's W-64 5" backing plate which is suitable for 5/8"-11UNC spindle thread could be turned for the first few rounds, as you mentioned. It works OK so far but I don't feel the sense of security of using it. So, I've ordered a M16 117mm (4.5") foam support backing plate from Flexipads for my Makita. You can find it from their website: Flexipads
Model number is 36357. They have backing plates for M14X2 as well. Cheers! | |
05-25-05, 02:07
| | UK Autopian
pugoman is offline
Join Date: Jan 2004 Location: Wiltshire, UK Posts: 818 | I recently bought a 'Flexipads' backing plate for my UK Makita and it didn't spin centrally, so I sent it back and got another one which was even worse! So I sent that back and got a refund. I was messing around for ages trying to centre the polishing pad to it... and then realised it was the backing plate that was causing it to spin off centre!
Your best bet is to get in touch with Meguiars UK and ask for their 14mm threaded backing plates... they do a 5" and a 6" backing plate. The product codes are SM-125 and SM-150. I have both... well I am an Autopian, what do ya expect! LOL
My name's Craig...
...and I'm addicted to detailing! | |
05-25-05, 02:10
zey is offline
Join Date: Nov 2001 Location: Kuala Lumpur, Malaysia Posts: 296 | Pugoman, thanks for your feedback. Unfortunately mine is a unit with M16X2 thread. I could only try the Flexipad's M16 backing pad. Anyway, the dealer is my friend, and it only costs me GBP5. If I'm not satisfied, I will not buy from him. Will try it tomorrow. Thanks! | |
05-25-05, 02:21
BenP is offline
Join Date: Feb 2005 Location: UK Posts: 794 | pugoman - the main reason I want a 5/8" spindle is that I'm eager to try the Edge 2000 pads as it will take all the hassle out of centering pads on a backing plate, but as of yet I haven't seen an adaptor for any spindle other than the 5/8".
Ben | |
05-25-05, 10:09
| | UK Autopian
pugoman is offline
Join Date: Jan 2004 Location: Wiltshire, UK Posts: 818 | Ben... a 14mm adaptor IS available for use with Edge pads. http://edgepads.com/Access.htm#
For High-Speed Buffers
• 5/8" thread (USA), Part #E206
• 14mm thread (Europe), Part #E210
• 16mm thread (Asia), Part #E213
My name's Craig...
05-25-05, 12:34
BenP is offline
Join Date: Feb 2005 Location: UK Posts: 794 | Bargain! Now the other question - do I import a US machine for $195 and risk getting stung for import tax, or just buy a UK one and accept our stupidly high prices (£170)...
Ben | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 02:16. | | | |
