Old 05-23-05, 07:37   #1 (permalink)
dom418 is offline
dom418 is on a distinguished road
Claying before buffing?
Hey guys, I used my PC for the first time this weekend. I first clayed the car followed by 3M fine cut rubbing compound, then 3M hand glaze then I finished it off with Pinnacle wax. It came out really nice. My question is is claying necessary if you are buffing out a car with rubbing compound? Or did I just waste my time?
Old 05-23-05, 07:40   #2 (permalink)
NEDM
JaredPointer's Avatar
JaredPointer is offline
JaredPointer is on a distinguished road
Send a message via AIM to JaredPointer Send a message via Yahoo to JaredPointer
IMHO, yes. Claying and polishing perform a similar job (cleaning/prepping the paint) in different ways. One does not omit the need for the other.
Man, it's a Gremlin, not a Pinto!!!
Old 05-23-05, 07:55   #3 (permalink)
My Arms Hurt!
usdm's Avatar
usdm is offline
usdm is on a distinguished road
You can clay without compounding or polishing.
But you should try to avoid compounding or
polishing without claying first.
Hope that makes sense..
God give them wisdom that have it...
And those that are fools, let them use their talents...
Old 05-23-05, 09:38   #4 (permalink)
Yeah, claying and compounding/polishing are two different things that are supposed to accomplish different tasks (even though there is some overlap).
Pulling [stuff] out of the paint with clay is different from abrading away both the paint and whatever's on/in it.
You did not waste your time and the claying almost certainly contributed to the good results.
Old 05-23-05, 09:55   #5 (permalink)
Citroeniste
butchdave's Avatar
butchdave is offline
butchdave is on a distinguished road
But DavidB stated recently that clay did not in fact pull stuff out of the paint, but instead sheered it off at the surface.
If this is the case then thats pretty much the same effect as compounding...
I can't believe you kiss your car good night.
C'mon baby tell me-you must be jokin', right!
Shania Twain
Citroen BX '88, Lomax 223 '85, Citroen 11BN '56
Old 05-23-05, 10:17   #6 (permalink)
I'm not about to with DavidB
Maybe I should've said "pulled it "off" the surface and from slightly below the surface". I *think* this is just a matter of semantics, but I don't see it as truly *shearing* contamination off exactly at the level of the surrounding paint or LSP. While clay doesn't always get *all* the (imbedded) contamination, it certainly does seem to get more than what's just lying on the surface.
Old 05-23-05, 09:19   #7 (permalink)
My Arms Hurt!
usdm's Avatar
usdm is offline
No, not quite. Claying (as well as any other paint cleaning
procedure) is meant to remove bonded contaminants. It
is not really meant to level or bring up the gloss of a painted
surface like polihing would. Granted, there are some clays
that are agressive enough to affect a leveling of paint (similar
to wet sanding). But that is only because that kind of clay
is geared toward removing heavy contamination. As a
by-product, it can abrade paint to a certain degree.
However, even an agressive clay would need a compound
or polish to level off the marring it could induce. Whatever
shine you see from claying is not because it can work
like compound or polish; the shine you do see, is a result
of contamination being removed, allowing for better clarity
of the paint surface.
Old 05-23-05, 11:08   #8 (permalink)
Administrator
DavidB's Avatar
DavidB is offline
Let's be really clear:
1. If you clay a single stage paint (no clear coat) that's in good condition, you won't see paint transfer onto your clay.
2. If you compound a single stage paint your pad is going to turn the color of the car... you are abrading the paint away.
Yes, using a compound will remove surface contamination, but it's by far the worst way to accomplish the task.
Why are you using a compound? I hope it is for one of the following reasons:
1. Remove scratches and other small defects.
2. Remove severe oxidation or severe swirl marks.
3. Blend a paint repair or knock down orange peel.
If you are using a compound for any other reason, you will be abusing your paint.
I may have to start handing out excessive compounding citations!
db
Autopia.org Mayor At-Large
Old 05-24-05, 06:19   #9 (permalink)
Bill D's Avatar
Bill D is offline
David B:
Diplomat,
The Society for the Prevention of Automotive Paint Abuse (SPAPA)
my product collection
My Detailing Credo
Old 05-25-05, 06:07   #10 (permalink)
dom418 is offline
I would never use rubbing compound in place of a good clay job. I used the compound to remove many hairline scratches and bring back the car's color from years never being waxed. I hope I didn't make it sound like I buff out my car monthly or else I would be down to bare metal by now. The car came out better than I expected and I am happy with the results. I just wanted to be sure I was following the right steps. Thanks for everyone's input!
Old 05-25-05, 07:14   #11 (permalink)
My Arms Hurt!
usdm's Avatar
usdm is offline
Post up some picks when you have a chance
