04-04-05, 07:28
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | What Pads to buy/How Many I am going to start using a Porter Cable and will be buying the Probel pads from www.exceldetail.com, I'm just not sure of how many and what ones to buy.
I plan on using the SSR1 and SSR2.5 with them on a large car. My swirls aren't too bad so I will probably go with the yellow on the 2.5 but am not sure about the color for the SSR1. How many of each pas will I need to get the job done? I will probably be using AIO and Z2 as well, what are good pads for those two products? | |
04-04-05, 07:31
| | Kayak detailer
White95Max is offline
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | I like using SSR2.5 with a green Propel pad. It also works well with a yellow pad for deeper swirls.
SSR1 would be used with a blue pad. AIO can be used with a blue pad or a finishing pad (gray I think?)
Z2 could be used with a finishing pad.
__________________ Paul...
04-04-05, 07:54
| | Street Rodder
Eliot Ness is offline
Join Date: Aug 2004 Location: Lexington, KY Posts: 3,114 | Start off with his starter kit (2 blue, 1 black/grey pad, and a backing plate). Then order 1 yellow, 1 orange, and 2 green pads and you'll have a very good set to start with that should cover most of your needs. This will give you two each of the most used pads (green and blue) if you decide to switch products or if a pad gets loaded up with product you won't have to stop and clean it while detailing.
As Paul said, start out with SSR2.5 on the green pad and then step up to the yellow or orange if needed. You can use the black (or grey) pad for Z, but if you read through some of the Z threads I think most members apply it by hand. | |
04-04-05, 07:55
Mr. Clean 2K is offline
Join Date: Feb 2004 Location: DISNEY WORLD Posts: 414 | IMO 2 of each... | |
04-04-05, 08:08
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | Yeah I would get more green and blue pads than anything else. Those are the ones you'll use most.
04-04-05, 08:17
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | So you guys this the Yellow may be too harsh? I have some shots of my paint here. Paint Pics
PS. Just ordered everything you guys said but I wasn't really paying attention, does the kit come with all the things I need for the porter cable to work? | |
04-04-05, 08:30
| | Street Rodder
Join Date: Aug 2004 Location: Lexington, KY Posts: 3,114 | Quote: Originally posted by Yaemish So you guys this the Yellow may be too harsh? I have some shots of my paint here.........
PS. Just ordered everything you guys said but I wasn't really paying attention, does the kit come with all the things I need for the porter cable to work? | Depends on how hard your paint is, but I'd start out with the green pad first. Do small areas (~ 2x2), spread it out on a slow speed (~3) then bump the PC speed up to 5 or 6 and move the PC very slowly to work the polish. If a couple of passes like this aren't removing the defects then you can step up to a more aggressive pad.
And yes, the Excel pad kit comes with a backing plate so all you need are the extra pads.
04-04-05, 09:08
| | Kayak detailer
Join Date: Jan 2004 Location: Stevens Point, WI Posts: 6,885 | The Propel pads work best with a 5" backing plate, so if your PC is coming with a 6", I'd recommend getting a 5" Propel backing plate from Excel when you order the pads.
04-04-05, 09:15
CutNAction is offline
Join Date: Sep 2004 Location: Coats, North Carolina Posts: 401 | I think the pad kit comes with a 5" backing plate. IMO you are going to want more of the green than anything.
1999 Grand Cherokee Limited V8 4X4 and I'm loving the power!
04-04-05, 09:32
Yaemish is offline
Join Date: Jul 2004 Location: New York Posts: 122 | One last question (hopefully), am I going to need the AIO after the SSRs or should I go right to my sealant? | |
04-04-05, 10:01
| | Kawi ZX6R owner
guapsnaman is offline
Join Date: May 2003 Location: Queens and Manhattan, NY Posts: 380 | From what I've read, YES. I will be using the same products you are and am planning on using AIO as the polish/cleaner after SSR2.5 and SSR1. Of course, after the AIO, SG x3 will be used for that extra shine and protection.
"...it is important never to forget where u all came from - becoz black, white, brown or pakistani we all come from de same place - de punani." -ali g
04-04-05, 10:21
| | I drive a station wagon!
J.J. is offline
Join Date: Mar 2005 Location: OH Posts: 1,125 | From what I've read, the AIO is not necessary after the SSR polish. SOme apply this product just for the "feel good" phenomenon. You can go straight to your LSP after the SSR IMO
__________________ MZ3 Hatch Zoom - Zoom | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:07. | | | |
