jucaraman.
As far as pads you may want to read this thread and try some Propel pads, there is also a link in there to another thread that describes them in more detail (what pad is good for what products, etc.):
http://autopia.org/forums/showthread...threadid=51257
After you clay, and before
AIO, you may want to use a polish if you have any paint defects you need to remove (swirls, marring, fine scratches, etc.). The prep you do with a polish is where you'll really bring out the shine on your finish, then the LSP (sealer and/or wax) will be icing on the cake.
If your defects aren't very serious you may want to try
Meg's #80, it isn't too abrasive but will remove minor defects and leave your finish looking very nice. From there you can go to AIO and then
NXT or straight to NXT. There are also a slew of other products out there and in time (and after looking at pictures in the Click and Brag forum) you may become like the rest of us and start trying a lot of other waxes and sealers to find what works and looks best to *you*.
Work #80 in a small area (~2x2) at a fast PC speed (~5 or so) with slow arm passes. Work it until it breaks down (it will turn clear or pink) and buff it off with a MF. You may need to do more than one pass to remove more stubborn defects, and if that doesn't work consider bumping up to a more aggressive polish (Meg's #83, Poorboy's SSR2.5, etc.). Good luck!
