Old 12-11-04, 03:10   #1 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
First time using my new Cyclo
Well guys, after receiving my new Cyclo almost a month ago I finally got a chance to try it out today. So far, I must say, I am not very impressed with it. I very quickly started to realize that the cyclo is more of a fine polishing/finishing tool than a compounding tool. I was under the impression that the cyclo could handle all the same paint defects as the PC, but be able to do the job in less time so I tried it out on my beater car. A 97' Ford Explorer with extreme clear coat failure on the hood. Obviously, clear coat failure is permanent and there is no fixing it but I wanted to try to make it not so obvious and I figured this is probably the toughest test I could possibly put the machine through. At first, the cyclo seemed very nice, very smooth and kind of does the work for you. All you have to do is hang on to it and guide it along. Even though it's smooth, it almost felt like I was holding a box with two cats fighting in it! and since the cyclo has two heads on it, it doesn't vibrate but kind of *shakes* instead. Even though it has two heads and is a very large and cumbersome machine, it is very easy to manage and handle. I was using two Cyclo yellow cutting pads with 1Z UPP on the hood, which is the worst part of the vehicle (as you can see in the pics). After about 5 minutes of using it, I started to get the feel for it and was just flowing along doing smaller 2ft by 2ft areas......then the problem struck. The tiny 4" pads clogged extremely fast, and was leaving a residue that just did NOT want to come off. I tried to clean them off with my pad cleaning brush from Autogeek, but all that did was tear the middle of the pads up so that was a mistake. I had enough pad to do the hood and then the cyclo was done. All I have are the pads it came with and that's only one pair of each grade. (cutting, polishing, and finishing). Since I didn't have any pads to put on the cyclo, I got out the PC and continued on with the detail. I've got to tell you, after using that big brute of a machine, the PC is SO NICE, and it left a much smoother surface than the cyclo did.
All in all, I didn't give the cyclo enough of a chance to prove itself yet and I still have some learning to do with it, but I can already see that it is going to probably be my go-to machine for very basic polishing and most paint cleaning products, maybe even LSP application but when it comes to aggressive polishing, there is no substitute for the PC, IMO. For smaller cars/projects I will always go or the PC, hands down.
Two things that didn't give the cyclo a fair comparison today. 1) I am using it on a surface that is unrepairable and in bad shape, which even a rotary couldn't make look good and 2) The Cyclo brand pads that it came with absolutely suck and thus makes the enitre machine seem worst than it actually is. This thing eats up pads like there's no tomorrow. I am thinking that I would have probably needed 8-10 cutting pads to do the compounding job I did with 1 PC pad today.
Here's some pics of the Explorer after it was washed and dried. For the newbies reading this, this is what you call clear coat failure at it's best. I almost forgot. After using 1Z UPP for a while, I switched to 3M PI II RC because it seems to be a little more aggressive than UPP and I ended up needing the most aggressive products I had in my arsenal. CC failure aside, I also had lots of scratches and scuffs to get out too, so I had my work cut out for me. I ended up spending about three hours compounding it today, and ran out of time before I could get any further, so I will try to finish it tomorrow. In the meantime, here's what it looked like this afternoon before I started:
Here's a closeup of the hood. I wonder if this was a paint defect or the result of something the previous owner did or didn't do.
Passenger side front door with some pretty deep scratches. I spent about 30 minutes on this door alone with the 3M RC
Pretty much all four fender lips looked like this
Old 12-11-04, 04:14   #2 (permalink)
mtodde's Avatar
mtodde is offline
Contact: Send a message via AIM to mtodde
Thanks for the write up Jason. After reading this, I'm wondering if the Cyclo is what I really want or not (hint to Santa). I was all sold after the rave reviews.
Did you try it in any areas without clear coat failure? I'm curious if that compounded the problem...pun intended, LOL. I remember reading that Scottwax started with is washing machine just to get the feel for it.
Please keep us posted as you master this new tool...and keep a pad count, LOL.
BTW, I noticed that Autogeek is carrying a Makita DA polisher that has a circular mode too. The model # is Makita BO6040; has anyone tried it?
Old 12-11-04, 04:25   #3 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
I used it a little bit on the fenders and it didn't have the cutting ability that the PC does, but it was after the pads were overloaded with product, so that might have killed anything else from happening.
The reason I don't have more pads is because I'm waiting for DavidB to update his website so I can buy the Sonus brand pads, instead of wasting my money on more Cyclo brand pads.
I may try the Cyclo out again tomorrow except with AIO too see how it does with that. I still have to go over the Explorer with 1Z PP before I can get to AIO though, so I still have a little more work before I get to the Cyclo stage again. I'll keep you posted.
One more thing. I'm not going to completely make up my mind until I get to use the Cyclo with Sonus pads on a near perfect surface. This way I can see what it leaves behind and I won't be using it for more than what is was designed for.
Old 12-11-04, 04:45   #4 (permalink)
Bill D's Avatar
Bill D is offline
What you need is a rotary to correct that paint if you're lucky. You confirmed my impression of the stock Cyclo pads: quality is subpar for what this machine calls for
I'd be interested in what their new orange pads and David's Sonus pads can do. I have no issues with product cake up with my vc LC pads
Definitely use the Cyclo on a more "Autopian" finish. I was able to successfully use IP on a spot area of my A4 and I also used it with good general polishing results on my Dad's ' Vette and that SL 55 AMG minus the deeper marring in that very tough Ceramiclear paint. The only car that really 'laughed at" my Cyclo was the Caddy, I'll try some more some other time but applying FP and removing Klasse SG via suede mf bonnets is still a pleasure.
For me these jobs will not go as smoothly if I just used the PC. I will use the PC for other kinds of odd jobs and I still use it exclusively to apply AIO.
Keep us posted about your upcoming impressions
my product collection
My Detailing Credo
Old 12-11-04, 05:01   #5 (permalink)
mtodde's Avatar
mtodde is offline
Does anyone know if the Cyclo pads Top of the LIne sells are LC or Cyclo?
Thanks!
Old 12-11-04, 05:03   #6 (permalink)
Bill D's Avatar
Bill D is offline
Cyclo brand AFAIK. I'm uncertain if those orange ones are the same ones Anthony Orosco reviewed. I thought those are coming out next year
My Detailing Credo
Old 12-11-04, 05:09   #7 (permalink)
Street Rodder
Eliot Ness's Avatar
Eliot Ness is offline
Can you use these 4" pads from CMA?
http://www.properautocare.com/4inspotreppa.html
I've got a set of them for my PC and they sure look like LC pads. Not sure if the "variable contact polish pocket" would be a problem with the Cyclo or not.
John
A.K.A. Eliot Ness
Old 12-11-04, 05:09   #8 (permalink)
I believe in you Eli
1 Clean WS6's Avatar
1 Clean WS6 is offline
Jason GREAT write-up!! Keep us posted as I am one of the many "on the fence" about getting a cyclo. It sounds like a great machine...I just want some more real world input on it before making the plunge.
Mike
My WS6
Old 12-11-04, 05:20   #9 (permalink)
Bill D's Avatar
Bill D is offline
I bet those will do good
My Detailing Credo
Old 12-11-04, 07:49   #10 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
Yes, I know. I am hoping to have a rotary under the Christmas tree and if I do I'll be tackling this hood again before 2005!
And, again, the yellow pads I used today sucked hands down. They were nice and stiff when I first started but by the time I finished they were as soft as pillows, full of caked up product, and worthless.
Agreed. I am definitely going to order them as soon as he updates his website because I think the biggest reason I am disappointed is because of the pads, not the machine even though the speed of the PC is what made the PC better today. Something to think about.
I will definitely keep everyone posted. I am not trying to discourage anyone from buying a Cyclo, so don't be afraid to get one because of my one experience. Keep in mind, that I subjected the machine to abnormal conditions today and with anything, there is a slight learning curve here. The biggest let down was the fact that it couldn't remove defects the way I was hoping it would. It seems like its going to be awesome for basic polishes, and even better with cleaners like AIO and VM, but that's not what I was buying it for so it's a little disappointing. There's no doubt in my mind that this is a good polisher, just not what I thought it was, that's all.
Old 12-11-04, 07:50   #11 (permalink)
Super Moderator
JDookie's Avatar
JDookie is offline
You have vc pads for the Cyclo?? Where did you get these? It's funny that you say this because the pad that I switched to was a 7.5" VC LC pad on the PC and that's what I used with the 3M RC and had no problems.
Old 12-11-04, 08:13   #12 (permalink)
Scottwax's Avatar
That paint is laquer checked. You aren't saving it even with a rotary. It looks to me none of those scratches are coming out either.
Like the other suggested, once you get some decent pads (I never had a problem with the green polishing pads) and a better surface to work with you will have better results. Make sure you clean the pads regularly. Since they are smaller and not as thick, they load up with product faster than PC pads. If the pads load up, you can get some hazing...no need to ask how I know, I am sure you can guess!
Scott's Mobile Auto Detailing
