Jakerooni- That's helpful info IMO with regard to figuring out what's going on!
I did a *lot* of "coarse-correct it then leave it for days" 105 work on some vehicles (me and my weeks-long projects :0 ).
I *did* find the micromarring was much more obvious after it sat for a while. Not quite the same thing as the more serious issues you're rediscovering, but maybe the same root cause- all the oils.
Similarly, I've had some pretty dramatic oils-dissipating issues when I used M205 on exterior plastics too..after a few days they looked *worse* than when I started!
I kinda suspect that your pads are making it harder for you to do uniform work and that the "kinda skipped over" areas are harder to spot because of the oils.
I wonder how IPA/PrepWash/etc. would help...might make it a lot easier to see the areas that need more attention.
Given your usually rotary-centric approach, I think it's perfectly understandable that some areas aren't getting quite enough correction; even when KMBing it's just not the same as hitting a panel with the rotary. Heh heh, yeah...even for *me*, and I'm Mr. so-NOT-a-Rotary-Meister
What size pads were you using, and which PC, the regular one?
Kevin Brown and I have kicked this around a few times, and those big pads just don't do it for me.
