Old 10-18-09, 04:24   #1 (permalink)
mike4690 is offline
Pad Diameter related to surface area treated
I have a pc that i have been using with some no name 5.5" pads and I'm wondering if I go with some 4" LC pads, would it be smart to use the smaller pads on the big areas like doors and hoods. I know that sounds complicated and a grammatical a mess but basically I'm asking should I use a 4" pad over the entire car, or should I save them for more compact areas and stick with the 5.5" pads for the bigger areas.
Old 10-18-09, 04:34   #2 (permalink)
the_invisible's Avatar
the_invisible is offline
Re: Pad Diameter related to surface area treated
I am sure you are aware that the use of smaller diameter pads is to reduce DA bog down.
Although you will likely gain slightly quicker correction using a 4" pad, you wouldn't see a noticeable difference. You may notice a greater difference if you have the less powerful non-XP 7424.
With m y 7424XP I am able to achieve close to maximum rotation speeds with the 5.5" pad. Although I always reach maximum rotation speed, 5.5" pad doesn't bog down much.
Rotary Usage theveed Machine Polishing 234 09-30-09 08:32
KBM Problem: overheating pad backing AudiOn19s Machine Polishing 20 07-21-09 08:40
Lots of questions about Pads and backing plates..... AlexRuiz Car Detailing 11 11-05-04 04:06
Just got the 7424 Bonus Kit from Coastal...what pads???? Young_Stallion Car Detailing 25 07-03-04 12:43
Machine Buffing DavidB Car Detailing 13 06-12-03 04:19
