Autopia.org
Old 03-12-03, 09:28   #61 (permalink)
BANNED FROM FORUM
Greg is offline
Greg is on a distinguished road
Mucho gracias. Dare I take the plunge? We shall see.
Does the need for a DA RO exist with a rotary buffer?
Old 03-13-03, 12:28   #62 (permalink)
Visit Big Bert's!
theveed's Avatar
theveed is offline
theveed is on a distinguished road
Send a message via ICQ to theveed Send a message via Yahoo to theveed
Originally posted by Anthony Orosco
Rotary rookies....
If you are kinda short you may need to get a step stool so that you are over and above the buffer as much as possible. This is very important. If you are right handed then your left hand will grab the handle WHICH by the way is NOT what you steer the buffer with. The handle should only be used to assist in guidance and balance. Far too many newbies PULL the buffer or PUSH the buffer with the handle which results in swirls. It will be natural your first few times to have a death grip on the buffer and your body will let you know this the next day by a sore wrist and/or forearm. Beads of sweat are also a clue
Best advice about "handling" IMO... I have a hard time putting this technique into words... but it's very true... The first time I practiced with a rotary I tried to "steer" the buffer head with the handle... it never worked out... after a while, using the whole buffer body to steer the head is much more effective, efficient and less tiring.
I also hold the buffer head itself and not the handle when working on vertical or tighter places, it gives me much better control... (Note that I have small hands and they fit in between the "C" handle of the Makita and the buffer head itself, so I'm pretty anchored).
Big Bert's Professional Detailers
Old 03-13-03, 01:51   #63 (permalink)
flyby's Avatar
flyby is offline
flyby is on a distinguished road
Send a message via AIM to flyby
ok, so i have light swirls, scratches on my dark green civic....my friend is going to loan my his rotary 8 or 9 inch he sed, dont know which model.
i was going to use
yellow polishing pads
1. dacp then
2. smr
3. glaze
4. #26 wax
and i am going to go really slow
or
could i use 3M smr (dark) by hand and be ok?
i read that dacp needs to be used with a rotary...
and i am not built like scottwax!!!! but i have all day to do this....
2000 Eclipse GT...modded
1996 Honda Civic EX cpe....slightly modded
Old 03-13-03, 04:07   #64 (permalink)
The Wax Monster
Green Monster's Avatar
Green Monster is offline
Green Monster is on a distinguished road
Send a message via AIM to Green Monster
Thanks Anthony Orosco for the advice.
I already have a few old cars lined up to practice on, so I don't have to worry so much and one of them is a dark brown Subrau which will help me see what I am doing.
Detailing a Car is a Work of Art Not a Job !!!
00 Green Ford Ranger XLT & 00 Blue Chevy Impala LS
Old 03-13-03, 04:35   #65 (permalink)
The Wax Monster
Ok which pad is the easiest to used or which do you suggest us to use?
CMA Finger Pads
CMA Advance Pads
The 3M Waffle Pad
Thanks again.
Old 03-13-03, 06:04   #66 (permalink)
Banned for Rule Violations
Anthony Orosco's Avatar
Anthony Orosco is offline
Anthony Orosco is on a distinguished road
Morning folks,
Glad to see ya'll didn't mind the long read.
Flyby,
If the swirls and/or scratches are truly "light" then I would skip the DACP and go straight to the SMR and a polishing pad. Work an area and then see how it looks. Remember as long as the paint is warm to the touch then you are safe and can repeat the application if the first one did not do the trick.
If you feel you still need more bite then use the polishing pad and the DACP.
GreenMonster,
I like the "finger" and the "waffle" pads over the Advanced pads if I am cutting or doing a mid-polishing step because they can work the product longer and one can control the heat build up better.
The Finger pads do tend to shed their fingers though if caught on an edge or molding piece. I personally prefer the Advanced Finishing pad for my last and final rotary pass using #9 or #3 or the sealant of my choice. I just get a better feel for the paint with one of these pads over the Finger and Waffle pads.
Also the combo of a rotary and PC or Cyclo is a good idea because one may only need to use the rotary on certain areas of the car, for instance the top sections, and finish out the rest of the car with the PC.
Good Luck folks
Anthony
Old 03-17-03, 07:30   #67 (permalink)
joed1228 is offline
Anthony - Great info, I was reading somewhere that it is better to hold the head of the buffer rather than the handle. It will allow the weight to be spread out in a more efficent manner and you can control it.
I found out on my own about the "move your body with the buffer" trick. Looks like I'm in soul train, I'm grooving! .......... until the machine starts hopping everywhere like a frog. I just purchased a spur and 4 more pads so I should be all set.
All I am worried about is inducing swirls and splatter. If I am not getting rid of that many swirls up front I can always learn better ways, if I am creating swirls and sending splatter everywhere customers are never going to come back.
Boston, MA auto detailer.
http://community.webshots.com/user/cleancamarojoe
Old 03-17-03, 08:31   #68 (permalink)
joed,
Thanks. The introduction of swirls at first is a given because you must program your mind and body to get into "buffer mode" and this takes some time.
In other words when people first begin using a high speed rotary they are hyper focused on one aspect. Either keeping the pad flat, keeping the splatter down, not burning the paint, to much or to little pressure, etc. What should and will happen over time is you will begin to become "all inclusive" and just automatically become aware of each aspect. I jokingly refer to this as "Zen Detailing" and one reaches it when one becomes one with the buffer, product and paint
Seriously though you will soon no longer focus or be distracted by those things and the funny thing is you will hardly notice when your buffing becomes second nature.
Just remember that no finish is 100% flawless because one can only work with the paint finish one is given. You cannot work out paint problems if the pigmented paint underneath the clear is flawed and each detailer needs to learn and know his or her limits.
For the "jumping frog" syndrome make sure you are not over buffing the product. Many times a water based cleaner/polish will not buff as long as say a solvent (mineral spirits) based cleaner/polish will. Work the product good at first but then cut back on the rpm's as it breaks down and begins to haze up. If not you will have a gummy residue build up on the pad and also on the paint, especially around contours and raised body lines.
Happy Detailing
Anthony
Old 03-23-03, 05:02   #69 (permalink)
joed1228 is offline
If that works I owe you a coffee or something man! It would be nice to use a pad for more than half of a hood.
Old 04-12-03, 08:30   #70 (permalink)
Blk300ZX is offline
Blk300ZX is on a distinguished road
Send a message via AIM to Blk300ZX
Great advice Orosco. The skipping pad is very bad to us. When it happens normally causes by the pad being off centered. There are new pads available and can be purchsed with a center "lock" for a perfect line everytime. I believe 3m makes them and the backing plate. I tried it today and saves much time and headaches.
Ryan
Yes! There must be a smarter way to do this.
Old 04-13-03, 08:18   #71 (permalink)
Thanks Ryan
I was reading over this thread and figured I need to mention that buffer "splatter", at least for me, is the last thing I am concerned about. I always, after a serious buffing, wash the car down anyways and remove the splatter.
Here is a trick that also helps to ease splatter clean up. Take an old pair of tube socks and cut out the toe end, you may need several of them since it's hard to find the "knee high" tube socks, unless your still living in the 80's!! You can then place these socks over the windshield wipers and arms. I also go through lots of painters masking tape. It looks like I am painting the car more so than polishing it.
You can also stuff newspaper into body seams and RUBBER CEMENT is a great masking agent. You can fill emblems and such with the rubber cement and when all done just peel it away.
Lastly, if a pad continues to hop and skip try buffing with it at a slight angle and this should eliminate or greatly reduce the skipping.
Anthony
Old 04-13-03, 09:50   #72 (permalink)
TheOzzfather
Guest
Posts: n/a
I have all of those pads and I really cant stand...
CMA Finger Pads
CMA Advance Pads
The 3M Waffle Pad
Thanks again.
The finger pads. Stick with the advance pads and the Orange power pads.
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/machine-polishing/12377-rotary-usage.html
Posted By For Type Date
Pagoda SL Forums - Orbital Polishers This thread Refback 11-13-06 08:02
(rotary usage) pad flat or not ? Chip Douglas Car Detailing 5 09-09-03 05:10
Makita 9227C Rotary polisher/sander theveed Detailing Product Discussion 0 07-08-02 06:40
DeWalt DW849 Rotary Buffer BradE Detailing Product Discussion 14 06-11-02 01:47
Rotary 101 JasonC8301 Professional Detailers 21 05-02-02 01:41
teaching to detail w/ rotary NY detailer Professional Detailers 4 04-09-02 08:31
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
