Submit Tools LinkBack (1) Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 11-21-02, 01:57   #49 (permalink)
Older & Wiser
Masterfinish is offline
Polishing 101
To attempt to teach buffing techniques by writing would most likely never work. Nothing like hands on will ever truly show a person how to use a high speed polisher. I can tell you that lower speeds help to reduce swirling, the reason being the amount of heat build up. The new clear coats and how to polish them is quite a science that old school detailers have a hard time accepting. Fact one is that heating the surface over 110 to 115 degrees with the friction of a spinning polishing pad can permanently damage the surface. A clouding affect can show up from over heating, thus the reason tyo keep the polisher moving slowly but steadily. The use of a digital infrared thermometer is a good tool to use when learning and can be a valuable sales tool. Just aim the unit at the surface and you get instant acurate readings to see how much heat is being created. Learning when to use twisted wool, synthetic/wool blend finishing pads and how and when to use foam cutting, polishing and finishing pads all come into play. The fact that you mentioned being able to practice on junk cars is a great way to learn. Reading your posts regarding skipping makes me think that because you could be polishing dirty, oxidized paint that you are getting a very quick build up of material on the fibers of your plishing pad. You need to spur it our thoroughly and often. Let the chemical do the work, do not push for more cutting power. If need be change to different levels of abrasive polishes. The pad and polisher is to make the work quicker and give a more evenly finished surface than you can do by hand. Working small areas, no more than 2 ft by 2 ft allows you to effectively work the area intended without drying to fast. Only apply product to the area you are ready to polish, never spreading polish out way ahead of where your working. That can cause permanent staining due to the solvents most polishes use as part of the cleaning chemical. The new clear coats have a UV (ultra violet) protection built into the top surface. The removal of more than .003 to .004 mils is the maximum depth a clear coat can be cut into. Any more reduces the UV protection which will cause sun damage to the base in a matter of months depending on the amount of sun the vehicle is exposed to. The only way to accurately tell how much material has been removed is to use a electronic digital paint thickness guage which costs several hundred dollars depending of the supplier. The thermometer can be found at any NAPA auto parts store for approx. $99.00. Due to the liabilty that comes with selling your services as a professional it is imperative that you have the proper equipment, training and knowledge before you accept a customers high dollar car and state that you will polish it safely and swirl free. This is a hugh subject and I'd be happy to answer specifics. With over 31 years experience and still learing everyday, I may be able to help.
Tom at Masterfinish
32 Years and Learning Every Day.
Old 12-31-02, 06:35   #50 (permalink)
Weekend Detailer UMD
THESANTINI is offline
Contact: Send a message via AIM to THESANTINI
Originally posted by Taxlady
DavidB wrote a great article about using machines for buffing and polishing. There is a whole section on using a rotary. It's in Detailing Articles and Tips:
Machine Buffing
I was looking for this and the link is now dead, can anyone help?
Young Investors
Old 01-17-03, 10:09   #51 (permalink)
tcsalon is offline
over the years, i have used the rotary buffer only when necessary. eventhough, i have become proficient with this machine, i have learned that most imperfections will not come out of a cars finish. my thoughts are that cars that come to you that need a high speed buffer on them, their owners could care less about their car, of course there are some exceptions. do you know the guy who gets a new car and is in your shop for the first month, once a week getting a hand wash? where did he go? my point is that most customers like to see a shinny car when they pick it up and a lasting wax over a time period. working w/ a high speed is very time consuming, b/c you usually have to do a 3 step process. cut, polish, wax. swirls, buffer mark and other problems arise. sure you can cover up swirl marks, but what is the customer going to think after a few washes? the bottom line is that the orbital buffer w/ a paint cleaner does a great job. follow it w/ wax and the exterior is done. you will be amazed by the results you get. i have a gem orbital and i use it w/ midnight special (on dark cars) then i follow w/ a coat of wax. you dont have to worry about the swirl marks and you essentially have piece of mind knowing the the customer is satisfied. i think that you shouldnt give your customers high expectations in regards to the exterior of a car. under promise and over deliver. thats how you retain clientelle. just a few thoughts. if you want more email me directly
tcsalon
Old 01-17-03, 10:15   #52 (permalink)
tcsalon is offline
wool only when necessary
keep the speed around 1500
swirls are created when temp of buffer to surface is over 115F
the products you use are important
keep the pad as clean as possible. (clean after each section)
drizzle product on surface, spread out w/ pad at low speed, start up and down, then corner to corner, then side to side. this should create enough heat to move the scratches, but not enough to create swirls, and enough movement to work the product in the paint.
just my experience
tcsalon
Old 03-04-03, 08:34   #53 (permalink)
kfcho is offline
I think i should be in this topic too..
THis is a sample of improper use of buffer on thick clearcoated s2000.
Old 03-04-03, 10:17   #54 (permalink)
barnacles!
Nagchampa's Avatar
Nagchampa is offline
Is it possible that the person polishing this vehicle used a heavy a compound (or wool pad) and failed to follow up with finer compounds and SMR? It is probably impossible to see the extent of it unless you are in person, but the car appears to be covered in rotary swirls.
HOLLA!!HOLLA!!HOLLA!
Old 03-07-03, 11:18   #55 (permalink)
Cornholio Rules!!!!
Smoker's Avatar
Smoker is offline
Looks JUST like the state of the wifes Ford Explorer.
Can these be removed with a DA or do they need the htting power of a rotary ?
Im a bit nervous of making it worse with a rotary, and if a PC will do the job safely, I'll gladly take the time needed.
Old 03-09-03, 07:20   #56 (permalink)
Visit Big Bert's!
theveed's Avatar
theveed is offline
Contact: Send a message via ICQ to theveed Send a message via Yahoo to theveed
If your wife's Explorer has buffer swirls, then a DA can remove it, but if it's a buffer burn then that's another story...
Big Bert's Professional Detailers
Old 03-12-03, 05:29   #57 (permalink)
The Wax Monster
Green Monster's Avatar
Green Monster is offline
Contact: Send a message via AIM to Green Monster
I have just received my PC 7428 Rotary for my b-day about a month ago and I am itching to use it but alittle scared.
I have use a Rotary about half of dozen times before and I have only use my new one to buff out a couple of sctraches. Worked well.
Now I want to work on the wife's car and remove the swirls.
Pad and polish selection help, please. Oh, and keep pad flat or on a slight angle? Thanks
(Waffle, Yellow or White foam, wool)??
(DACP,#2,#3,#4, or 3M fine, medium, finesse-it)??
Detailing a Car is a Work of Art Not a Job !!!
00 Green Ford Ranger XLT & 00 Blue Chevy Impala LS
Old 03-12-03, 08:26   #58 (permalink)
Greg is offline
Green Monster- I think you and I are the only one's who want to get down to this rotary business. Ahh...I want to know what I should expect, how it works, what types of pads, compounds/polishes.
Old 03-12-03, 08:31   #59 (permalink)
Anthony Orosco's Avatar
Anthony Orosco is offline
Rotary rookies....
Speed, pad choice and product choice all come by hands on experience. This is a totally subjective area and the only objective thing about high speed use is that it can be a dangerous tool if taken lightly.
I cannot stress enough how important it is to practice on an older car or a scrap hood or door. I even suggest that you intentionally burn the paint on the scrap pieces so you know just how much heat and friction it takes plus you will know what a "burn" looks like hence you can perhaps prevent it from happening when doing your own car or worse a customers. Use different pads for the burning like foam cutting pads and wool cutting pads and you will see that foam pads, the non-waffle type, actually heat up quicker than the wool pads because the wool pads allow more air flow.
I have several wool pads but honestly I rarely use them. I prefer to use mainly polishing pads and finishing pads and rarely ever dial past 1800 rpms. If you have a polisher with a variable speed trigger than learn how to lightly squeeze the trigger just half way so you can rev from a few hundred rpm's to your dialed rpm limit, say a 1000. This technique comes in very handy for buffing up next to edges and body lines.
OK, lets buff out a section of a hood. The hood has very light oxidation, minimal swirls. My first step after washing would be to clay that hood thus removing the light oxidation. We then tape off all areas prone to get buffer residue and splatter like windshield wipers and washers. Since we have removed the oxidation we can go with a product designed to remove light swirls and scratches and not worry about removing oxidation.
The problem is not serious enough to justify a cutting pad or a wool pad and a finishing pad would be far to mild to work the product so a polishing pad is what we need. Set the buffer at about 1000 to 1200, I personally (depending on what product I am using) like to mist my pad with a QD. In your head pick out a section about 2x2 in the middle of the hood and apply a light bead of cleaner to the pad. Now many people suggest to apply this in a circle on the outside of the pad or apply a quarter size drop close to the center of the pad. I have found that this depends on what area you are buffing. For large areas, like our hood, I apply the polish in a circle around the pad and if I am buffing a small edge, say around the curve of a bumper, I might apply a small drop to the paint itself and with a slow rev spread the product and cover an area then slowy increase speed.
So we will apply a small bead of product on our pad around the edge and lay the buffer cord over our shoulder,lay the buffer down flat and make sure you are NOT over extended as this will result in buffer hop. If you are kinda short you may need to get a step stool so that you are over and above the buffer as much as possible. This is very important. If you are right handed then your left hand will grab the handle WHICH by the way is NOT what you steer the buffer with. The handle should only be used to assist in guidance and balance. Far too many newbies PULL the buffer or PUSH the buffer with the handle which results in swirls. It will be natural your first few times to have a death grip on the buffer and your body will let you know this the next day by a sore wrist and/or forearm. Beads of sweat are also a clue
Mentally check yourself every so often that you are not clutching the buffer too tight on the extended handle because this will cause you to tilt the pad. You should be able to release the handle while buffing (on a flat surface) and the buffer will glide across the surface. I buff with my right hand working the trigger and my left hand rests lightly on the top of the buffer just above the spindle lock or no left hand at all.
Slowly press the trigger and as the pad begins to spin draw the 2x2 outline with the pad and product and then while slowly increasing speed move the buffer into a figure 8 pattern WITHIN your box. Concentrate right now on the control of speed and movement and not how or if the product is working because with the correct control of speed and movement the product will work!
The pad does NOT need to lie completly flat at all times for this is impossible. One would go nuts trying to buff out a 911, with all of its contours, and keep the pad flat to the paint. Some pads are designed to work better with a slight tilt of the pad. Swirls are introduced into the finish by over tilting but more so by the wrong choice and/or combination of aggressive pad and product.
I get asked quite often, "How do I know when to stop buffing?" That is a question that can only be answered by expereince. While I am buffing I look at the paint and product on the paint and dart my eyes from the area I am doing to the area next to it and I also watch how the product is being worked. As long as you are moving the buffer with slow but steady passes in your boxed area and their is still product to work there is little need to worry about paint burn. After a few moments feel the area you just buffed by laying your palm down on it. If it is just warm then you are doing everything correct, if it is hot then you are working too small of an area for too long of a time OR too high of a speed for the area. Another factor could also be that you need more product.
After 14 years of buffing I can pretty much look at a panel and mentally determine how much product will be needed and for how long but with time and expereince this will also come your way.
Also remember to move the buffer with your body and not just your hands. The ideal movement is that your upper torso, shoulders and hands all move in unison WITH the buffer. This takes some practice. And DON'T forget to breathe as you are buffing because lots of times newbies, in being nervous, hold their breathe and become very ridgid which almost always results in mistakes and frustration. Practice, practice, practice.
Lastly, if your pad seems to be skipping then remove it and rinse it out. On an average car I may rinse out my pad three or four times. Well I apologize for the long post but have fun and enjoy the experience. If I can be of anymore help please let me know.
Anthony
Old 03-12-03, 09:35   #60 (permalink)
barnacles!
Nagchampa's Avatar
Excellent post Anthony! I can visualize exactly what you are describing.
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/machine-polishing/12377-rotary-usage.html
Posted By For Type Date
Pagoda SL Forums - Orbital Polishers This thread Refback 11-13-06 09:02
