Yes, the Chemical Guys and Adam's pads are indeed produced by Buff and Shine. Unfortunately Buff and Shine doesn't sell pads of this foam type and design to the public. Their foam types are very distinctive from those of
Lake Country. I think I prefer the
Lake Country pads over the Buff and Shine ones. I do, however, recommend the Adam's Polishes to those that do not want to have to figure out which pad is which among the many types of pads produced by LC.
Originally Posted by Chicagoareanew
I know I'm new at polishing, but at this point I am convinced it's the pads and not me. Even with priming, giving them breaks, cleaning them with DP pad cleaner, they soften up which defeats the purpose of having orange pads. And then they lose control, where instead of spinning they freeze for a split second and then do something unpredictable. I'm pretty sure at this point it can't be my technique because it starts out ok, but then goes down hill.
So, I'm wondering if Chemical Guys has good pads. They seem to have a pretty big selection; it's smaller than LC but they have too many anyhow. I know some people like Meg's pads, but I don't like that brand in general.
Edit: I'm willing to consider anything, not just CG but they are the only other brand I know of.
Have you tried other different brands of pads in order to justify your claim? Seeing that you so eloquently express your distaste for a particular brand, I doubt you have tried out the next popular brand of pads. Therefore, I am fairly convinced that you are either not familiar with the nature of polishing pads or that you are not using your supplies correctly, or both. The fact of the matter is, you will probably face the same problem even if you switch to another brand of pads. Pads tend to soften up when they absorb the oil and liquid contained in compounds or polishes. Even more so, priming the pads soften them up even more.
Once in a while, I mess up my buffing process by simply using too much product and working them for too long with some compound, which creates excessive gumming and pad contamination. However, even with the gumming and contamination, the pads still work satisfactorily.
Sometimes depending on the clear coat hardness and compound used, cleaning on the fly may not sufficiently restore the pads' cutting power. It is almost crucial to have at least three pads for one car. Some people may be able to buff out an entire car with just one or two pads, but you never know if you will eventually need some extra pads in case you run out of pads.
Keep in mind that
Lake Country is probably one of the leaders of polishing pads technology. If you find their pads not up to your standard, then I am afraid you will not be too satisfied with the other ones as well.
