right so...
went to lowes and picked up a 1000watt halogen worklight set as I knew I was going to be working way past sunlight.
spot washed the trunk lid and split the top panel into two halves.
each half took three hits with the orange pad/SIP combo.
1 hit = 3passes slow speed/heavy pressure; 2-3 passes moderate speed/moderate pressure.
followed up with 1 hit with blue pad/106FA
(all my pads are the uber variety from DD)
this did get a pretty good result.
i can't really judge on the percentage scale but a good majority of the swirls were gone under the halogens.
it's been overcast all day so I'm still not able to check under bright, direct sunlight.
6hits overall on one panel seems way too much for me.
it took over an hour and I can't imagine trying to do an entire car at that rate.
I'll most likely try a yellow pad from DD with SIP next.
And if even that takes a while then move up to
M105.
on a side note, yesterdays work produced an INSANE amount of dust.
i thought i rinsed it all off but noticed a good amount of white specks on the neighboring panels in the morning.
gave it a wash midday and they are still there (have to be rubbed with some pressure to remove it seems)
so, as noob as this might sound, what's the best way to make sure all the dust gets rinsed off cleanly?
and when you do an entire car, do you rinse after every panel or do you wait till the end?
also, feel free to comment/add on to anything else mentioned.
I feel some satisfaction at the results but really wish it could be shortened time wise.
