Better be careful with that water addition business. I've done it (also used #34) and I did fine, but IMO that is in the "don't try this at home, kids" category. Check the pad often for clumped product and, well, don't blame me if you instill some *REALLY* awful marring. It really could lead to a *very* serious "oops" that you'll truly regret. I'm not kidding....
If the new/v2.0
M105 is drying out too fast, IMO you're either not priming the pad properly, or the panel is too hot, or you're working too large of an area. Or you're trying to use it the way you'd use a different product.
It's simply *different* from diminishing-abrasive products and it's used in a different way. Yeah, there can be a lot more pad cleaning with
M105.
If you want more cut from it use a different machine or a harsher pad (3.5" and 4" PFW and Cyclo/Edge yellow and blue wool come to mind, but be careful with the yellow and even the blue can leave some real marks). I used the PC/M105/3.5" PFW combo on some *really* bad marring on *hard* clear the other day; took me right to the "barely any clear left" point just fine but it did take a few (section) passes.
But don't expect the PC to remove any serious marring with just one or three goes even with
M105 no matter what pads you use..it's still a PC
