Old 06-30-09, 08:26   #1 (permalink)
mhuie is offline
Fine pitting
I've just noticed that if I look at my car under fluorescents, I can see fine pitting all over my car. I've never noticed it otherwise and the car does look good.
I don't have a huge arsenal of products, but I tried wetsanding an area with 2K, a PC with M105 (yellow) then M205 (orange), and that pitting is still there. I've tried 106FF with a white pad on the same area also.
Is it that I need to go harsher or go with a finer polish/pad combo? - or it is something else?
BMW E34 530i
BMW E38 740i Sport
Old 06-30-09, 08:44   #2 (permalink)
Legacy99's Avatar
Legacy99 is offline
Re: Fine pitting
How deep is the pitting? Couldn't you tell that the pitting was still there as you were sanding?
Old 06-30-09, 08:52   #3 (permalink)
landcruiser's Avatar
landcruiser is offline
Re: Fine pitting
IMHO, this pitting is pretty much a fact of life due to road debris. I have this same thing on the hood of my Porsche. I suppose the only real solution is re-spray of the affected areas, then clear bra--if you're so inclined.
I say drive your cars and enjoy them and adopt the "5 foot rule". If it looks good from 5 feet away, you're good to go. It gets to the point where you'll drive yourself crazy trying to have zero flaws--unless you don't want to drive it.
Just my .02.
Old 06-30-09, 08:54   #4 (permalink)
BigAl3 is online now
Re: Fine pitting
the fine pitting can also be caused by using an aggressive polish/compound and not following it up with a finer/less aggressive one...
Old 06-30-09, 08:56   #5 (permalink)
yo2tup is offline
Re: Fine pitting
Just my .02.
I like that rule!
Old 06-30-09, 09:08   #6 (permalink)
mhuie is offline
Re: Fine pitting
Not very, you can't feel it at all if you run your finger over it, even while sanding. Its only noticeable from a few inches away.
BMW E34 530i
BMW E38 740i Sport
Old 06-30-09, 09:16   #7 (permalink)
Dunncsu is offline
Re: Fine pitting
YOU are the only one that will ever inspect your car that closely.
I like the 5 ft rule
Old 06-30-09, 09:19   #8 (permalink)
Legacy99's Avatar
Legacy99 is offline
Re: Fine pitting
You should have seen the marks when applying water. Don't know if going to 1500 is worth it.
Old 06-30-09, 09:49   #9 (permalink)
Re: Fine pitting
Hmmm, I've never experienced that. Do you have any photo samples of this? What do you attribute this to? Incomplete particle break down?
My concern for the OP would be continuing to abrade the surface in an attempt to remove all of the pitting and having on "oops" moment. I tend to pay attention to swirls and correcting them as a reference. The pits are, well, the pits!
Old 06-30-09, 10:02   #10 (permalink)
mhuie is offline
Re: Fine pitting
Just my .02.
That's what I figured. This is the first time I'm polishing my car fairly aggressively (and checking it so closely), so I wasn't sure if this is normal or if I was doing something wrong.
BMW E34 530i
BMW E38 740i Sport
Old 06-30-09, 10:03   #11 (permalink)
Auto Concierge's Avatar
Auto Concierge is offline
Re: Fine pitting
Most likely acid rain damage, the fallout will put microscopic craters in the finish which looks like a**.
Bob Willis
Serving the Ferrari, Lamborghini and Porsche community
Since 1994
Old 07-01-09, 01:58   #12 (permalink)
Re: Fine pitting
here are a few threads on the SSR line...
Pitting with SSR polishes
SSR 2.5 routine and also why does it create mini craters / pits
Scratch X put in some fine scratches pdsterns Car Detailing 4 07-30-05 11:41
Help with fine scratches Asmodaus Car Detailing 6 06-15-05 12:31
compare/contrast 3M FI-II fine cut VS. DACP blackntan Car Detailing Product Discussion 3 07-05-04 07:08
Fine Scratch problem Drew T. Car Detailing 2 06-16-04 06:22
Really fine scratches.. Gene Arch Car Detailing 8 10-29-01 02:40
