12-31-08, 06:57
Xcessiv is offline
Flex 3401 - Is this normal???
8 months ago, I bought a Flex 3401 to avoid reliability issues with other models like the UDM. I was fully aware of its limitation, like its fragility when applying too much pressure on the extremities.
I think this wasn't enough because 6 months after the purchase and around 5 jobs later, what looked like a tiny plastic ring came off the plate. I ensured that the Allen bolt was tightened properly and everything was perfect. I therefore completed the job flawlessly, without a single sign of abnormal wear.
Today, 2 months after this incident, I decided to open the Flex and see what was going on to be sure that there was nothing wrong and that I'd be ready for the next jobs. The first noticeable thing before removing the plate was a very minor backlash up and down; maybe 1mm. After opening everything, here's the result:
I really don't think this is normal; is it? Should I send it back? Is this typically covered by the warranty?
400+ hp supercharged Mustang GT 2001
11.6 @ 121 mph
12-31-08, 07:03
Setec Astronomy is offline
Re: Flex 3401 - Is this normal???
Isn't this the felt ring issue? Where you have to put some lube on it or something or it rubs the backing plate and overheats.
Grumpy like Ketch...
"Well, it certainly does!"
12-31-08, 07:05
Xcessiv is offline
Maybe, but I wasn't aware of this and now I guess it's too late.
11.6 @ 121 mph
12-31-08, 08:59
David Strum
weekendwarrior is offline
Contact the vendor of your Flex. Mine stepped up and sent me a replacement plate and ring free of charge. I lubed the new ring, and no problems since.
DS Mobile Detailing, LLC
12-31-08, 09:19
Sheesh, another Flex lube issue...what did the vendor say about why this happened, did they suggest the lube, what kind did you use?
12-31-08, 09:25
David Strum
My vendor said some plates act up, and some don't. They just sent me a new one. I think I used 3 in 1 oil, but I can't remember. Air tool oil, sewing machine oil, and even motor oil will work as far as I know.
12-31-08, 10:06
So they didn't say it should be lubricated periodically? I think someone said they used synthetic motor oil.
12-31-08, 10:27
Bottom Feeder
wfedwar is offline
You have two problems. First, the backing plate/felt ring lube issue already discussed. Second, the ring gear is worn. That's where your 1 mm play is coming from. The gear on the backing plate is worn too, but that's getting replaced. I'd try to get a new ring gear before it all goes back together because it may wear out your new backing plate gear more quickly.
12-31-08, 11:36
Xcessiv is offline
Excellent observation! I guess you're talking about the picture below, but I was also talking about backlash in the other axe: up and down. I'll ask for a replacement gear.
11.6 @ 121 mph
12-31-08, 11:38
Xcessiv is offline
No one ever told me to lube this part. Before buying my flex, I posted on many many many discussion boards without any comment about this. My vendor (Eshine) didn't communicate this information either.
11.6 @ 121 mph
12-31-08, 12:35
Bottom Feeder
wfedwar is offline
Don't feel bad about it. I got mine and only knew about the issue from posts on here. I specifically looked for any mention of this in the literature supplied with my buffer and I couldn't find it. I've never seen anything that says that this is a recommendation from Flex.
01-02-09, 09:43
Exelero is offline
i was told by flex to use a garage door spray lube you can get in lowes or home depot.after several calls and getting someone who new what they were talking about an had an enough english this is what i was told.use the garage spray lube they use it on the rails cause it is a spray gets in tight areas and dries instant to a gel that sticks very well to the parts an last for almost ever.i use this stuff on everything now it lubes an stays where you put it.
