Re: Ultrafina? Danase Swirl Abolisher, ZPC?
What color is your car?
You could try the ZPC with one of the lighter pads to see how well it finishes off. I'd recommend using speed 4.5-5.
If you feel you need a little finer finish, I'd recommend Optimum Poliseal. It's relatively inexpensive, super easy to apply and take off, and can act either as a light polish, or a topper with durability. I'd recommend using some 5.5" pads though. The 4" are great if you need to do heavier correction with a pc, but will seriously slow down the process for final polishing or application of toppers.
UF SE is great stuff, but you really need a rotary to use it properly, and it's expensive.
Todd Cooperider
Esoteric Auto Detail, LLC
