Old 07-05-08, 04:51   #1 (permalink)
ArMiXiA is offline
ArMiXiA is on a distinguished road
PC Routine
Planning to do a detail and this is my following routine i plan to follow : (Any advice is appreciated)
I own a black WRX and it is a swirl magnet
1). Wash, clay, wash...
2). Optimum Polish with PC
3). Klasse AIO or SG not sure of which
4). P21S
Any advice or tips?
Also my PC7424 overheats after about 5-10min of usage on setting 1 even. Does that happen to anyone else and should I just call it a loss and order a new one? Its brand new but has been in my garage for about 1 year and a few months so I doubt I can return it. I did just open it though. After 5min you smell plastic burning and you cannot touch it due to it being so hot, you have to use the screw in grip or else you cant use it at all. Thanks again!
Last but not least: If I do need to just buy a new polisher how does the griot's garage random orbital stack up against the PC?
Old 07-05-08, 05:19   #2 (permalink)
Krazy Klean
Saleenman607's Avatar
Saleenman607 is offline
Saleenman607 is on a distinguished road
Re: PC Routine
4). P21S
Any advice or tips?
Sure sounds like the pc is faulty. I'd take steps to R&R it. Your routine seems OK. However your question to yourself should be "Why are there swirls in my paint?" Are you or someone causing them? Usually there created with poor washing techniques. See Accumulators wash regimen.
Above all......have fun with the process Mr. ArMiXiA
I Don't Know Karate.....But I Know KRAAZZY!!
Old 07-05-08, 05:23   #3 (permalink)
BigAl3 is offline
Re: PC Routine
it shouldn't overheat on speed 1 and you can't really do anything at that setting anyway. pass on the griots and get either a UDM or Flex...
YouTube - Flex XC 3401 VRG vs. Porter Cable 7424
Old 07-06-08, 11:31   #4 (permalink)
Re: PC Routine
ArMiXiA- Welcome to Autopia!
If your PC acts up when using normal speeds (4-6), then it needs serviced. Even a complete rebuild is pretty cheap (so cheap I forget what it cost...it wasn't worth remembering) and PC service places are usually pretty easy to find. And the place you got it from might look the other way regarding the time since purchase, wouldn't hurt to ask.
Rebuilding it would certainly cost less than a Griot's machine (or anything else), but if you get the latter, make sure it can take smaller backing plates for the use of 3.5-4" pads.
Old 07-06-08, 12:15   #5 (permalink)
Legacy99's Avatar
Legacy99 is offline
Legacy99 is on a distinguished road
Re: PC Routine
4). P21S
Any advice or tips?
Did you use the spacer between the shaft and backing plate?
Old 07-06-08, 01:15   #6 (permalink)
citizen arcane's Avatar
citizen arcane is offline
citizen arcane is on a distinguished road
Re: PC Routine
Bingo! I believe that is the answer as well.
Originally Posted by ptaylor_9849
Black is not a color, it's a part time job. Patrick
Old 07-06-08, 04:19   #7 (permalink)
ArMiXiA is offline
Re: PC Routine
Hey thanks guys for the quick replies can anyone tell me where and how to get the PC serviced? Autogeek will not cover it since its over 1 year thanks again!
Old 07-06-08, 04:24   #8 (permalink)
Street Rodder
Eliot Ness's Avatar
Eliot Ness is offline
Re: PC Routine
Change the drop-down menu from Delta Machinery to Porter Cable and then enter in your zip code:
Service & Support
Check and make sure your backing plate isn't rubbing before you go to the trouble of taking it to a service center. The purpose of the of the spacer mentioned is to keep the backing plate spaced out from the housing so it won't rub. You don't actually need the spacer as long as you have the backing plate spaced out enough to not rub.
John
A.K.A. Eliot Ness
SSR 2.5 routine and also why does it create mini craters / pits flightz71 Car Detailing Product Discussion 23 08-24-07 09:21
Weight Routine dcswd Detailing the Man 32 07-20-05 12:42
Input on my Wax routine batson34 Car Detailing 1 07-21-04 09:09
Quarterly Detail Routine weegee Car Detailing 9 08-14-03 06:09
3M SMR as a routine polish? ruangvith Car Detailing 2 10-01-02 07:20
