07-03-08, 08:57
advs1 is offline
Join Date: Mar 2008 Location: whittier Posts: 298 | hologram/swirl reappearing ok, i have posted a few times about my uses with my new rotary, a hitachi. well yesterday i thought i had finally figured out a combo of pads and polish that worked. i was using a blue lc pad and CG pro polish. i have 2 1200 watt halogens i was using in doors yesterday. after 50/50 wipe, it seemed i had gotten all the scratches and swirls out. i wiped the panels down and checked then in sun light. i saw nothing, i mean no marks, holograms, except for very deep scratches i would have to color sand out. well this morning i walk out and check my car and there are swirls, scratches and holograms!! i mean i spent hours yesterday working these out, and by all my accounts they were gone. i even showed my wife and she gave me the thumbs up. i dont understand why after one night they would return or be visible when yesterday the panels were almost perfect, even in sunlight??
i'm about to give up on the rotary, even though it produces a sharper, much more reflective shine than my previous experiences with the flex or pc. i really want to master the rotary but what am i doing wrong??  | |
07-03-08, 09:34
| | Now with twice the head
Join Date: Oct 2001 Location: Arlington, TX Posts: 25,509 | Re: hologram/swirl reappearing You didn't finish with 3M Ultrafina and a blue Ultrafina pad.
/thread | |
07-03-08, 09:38
advs1 is offline
Join Date: Mar 2008 Location: whittier Posts: 298 | Re: hologram/swirl reappearing Quote:
Originally Posted by Scottwax You didn't finish with 3M Ultrafina and a blue Ultrafina pad.
/thread | ok i'm asking because i dont like 3m products, do i have to finish with 3m ultrafina?? i mean is there nothing else that it could be? | |
07-03-08, 09:47
Legacy99 is offline
Join Date: Dec 2007 Posts: 891 | Re: hologram/swirl reappearing It looks like you didnt remove all the oils even after a IPA wipe down. Only answer I can think of. Try using Prep Sol next time. | |
07-03-08, 09:51
advs1 is offline
Originally Posted by Legacy99 It looks like you didnt remove all the oils even after a IPA wipe down. Only answer I can think of. Try using Prep Sol next time. | note to self: buy prep sol asap. thank you | |
07-03-08, 10:59
Join Date: Oct 2001 Location: Arlington, TX Posts: 25,509 | Re: hologram/swirl reappearing Quote:
Originally Posted by advs1 ok i'm asking because i dont like 3m products, do i have to finish with 3m ultrafina?? i mean is there nothing else that it could be? | I know of nothing else that finishes down as consistantly hologram free as Ultrafina. Not a huge 3M fan otherwise, but UF flat rocks. Everyone else in the industry is now playing catch-up, IMO.
Two things to remember:
1. It won't remove severe holograms
2. Follow the directions exactly | |
07-03-08, 11:16
advs1 is offline
Originally Posted by Scottwax I know of nothing else that finishes down as consistantly hologram free as Ultrafina. Not a huge 3M fan otherwise, but UF flat rocks. Everyone else in the industry is now playing catch-up, IMO.
2. Follow the directions exactly | can you give me a little low down on the directions? i've seen that posted somewhere else and it scares me a little. kinda like if i dont follow then my car will melt | |
07-04-08, 01:08
| | 0 to 60 in one paycheck!
SuperBee364 is offline
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,870 | Re: hologram/swirl reappearing Quote:
2. Follow the directions exactly | Even on the very softest paints, UF finishes down hologram free with a no-bite pad. 1Z High Gloss polish makes black Bentley paint look like you just wet sanded it, yet UF finishes it off flawlessly. I totally agree with Scott: everyone else *is* playing catch-up. | |
07-04-08, 03:14
Legacy99 is offline
Join Date: Dec 2007 Posts: 891 | Re: hologram/swirl reappearing Quote:
Originally Posted by advs1 can you give me a little low down on the directions? i've seen that posted somewhere else and it scares me a little. kinda like if i dont follow then my car will melt | It scares you to follow directions | |
07-04-08, 03:47
| | U Bring It - I Bling It
David Fermani is offline
Join Date: Aug 2004 Location: S. Florida Posts: 3,166 | Re: hologram/swirl reappearing Keep in mind that UF is an incredible finisher, but unless the polishing steps prior to it don't bring the finish to an almost perfect appearance, it could hide defects. I like to use UF just to insure that the finish is 100% swirl free. In other words, don't go right to UF right after a moderate to heavy defect removal stage.
Here's a 3M video you should watch: 3M
__________________ The Perfection is in the Reflection | |
07-04-08, 07:27
TH0001 is offline
Join Date: Mar 2006 Location: Orlando/Oveido Posts: 2,653 | Re: hologram/swirl reappearing Quote:
Originally Posted by David Fermani Keep in mind that UF is an incredible finisher, but unless the polishing steps prior to it don't bring the finish to an almost perfect appearance, it could hide defects. I like to use UF just to insure that the finish is 100% swirl free. In other words, don't go right to UF right after a moderate to heavy defect removal stage.
Here's a 3M video you should watch: 3M | Bingo... UF fills much like Menz 106ff.. Do not be suprised to see marring returning several months after polishing
The only way to ensure (and there is really no way to ensure) there is ZERO holograms/pad abrasion is to never skip a step and use logic... Finish with two polishing steps, one with a light abrasive pad and one with zero abrasive quality (mechanical action).
I would say that every polish fills to some degree and that if you are looking for the best possible results you might not want to copy what you see in the click and brags but follow the advice of the top pros (like Mr. Fermani). | |
07-04-08, 08:12
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,766 | Re: hologram/swirl reappearing Quote:
Originally Posted by TH0001 Bingo... UF fills much like Menz 106ff.. Do not be suprised to see marring returning several months after polishing... | Huh, never heard that before. Does a PrepSol wipe (after UF) show the paint's true condition? | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 11:19. | | | |
