Originally Posted by DennisH
Be sure to check the allen screw that holds the backing plate on, there have been a bunch of loose ones from the factory that has caused damage to the backing plate. I would also check it before each detail.
Cool, thanks for the heads up.
Originally Posted by Legacy99
Do you stil have to oil the material type O ring?
Not sure...maybe someone else can chime in. Why do you have to oil it?
Originally Posted by Kenney
where did you order it from?
I ordered it from Detailed Image. Great service, quick shipment and a good bit cheaper than some of the other sites.
