Hi there.
Im quite new to machine polishing. I have polished about 10 cars or so with a cotech machine. Kinda the same as cyclo machine only much cheaper and probably not as good.. Im using cyclo pads for it and the results have been rather good.
But I would like to step it up a notch, Because the cotech polisher isn't a killer when it comes to removing imperfections on the paint.. It just isn't cutting enough it seems like. but it is exellent on lighter swirls and so.
So now I'm stepping up a notch and buying the
flex 3401 VRG DA and see if this can give me any better results. Hopefully it will since its quite expensive IMO. And I'm also buying a makita rotary since from what I read this is one of the machines that give the best result, But ofcourse is harder to use than a DA machine.
But here's to my questions..
I have a black 95 supra TT and a black VW passat 05 TDI 4Motion and I know if I just started using a rotary on them I know it would turn into FUBAR. But what I would like to know is.
What is the best way to learn to detail the best.. Should I do like I said.. buy the
flex and learn from that machine and then use a rotary or should I just buy the makita and keep going on scrap panels until im satisfied with the results and then jump on it and try on a "real car". Any input on what I should start off with and what not.
and is it the rotary that gives the best result, or can you achieve the same with a DA. I know the rotary is better on severe paint imperfections, But if you can remove the imperfections with a DA would you get the same result, or is the rotary superior in all categories as long as it is used right. ?
Any inputs from experienced detailers are higly appreciated. I have a good amount of money to spend on machines so that is not an issue. But I would like to learn how to do it right instead of just throw money down the drain and ending up with a bad result.
I could ofcourse just send my cars to a proffesional detailer every now and then. But I really enjoy the polishing so I would never let other people take that away from me. And there is something about that feeling knowing you did it yourself.
Thank you very much for reading my post.
Robert
Norway
