Originally Posted by toby tyke ............. the backing plate is far bigger than my normal CCS pads, does the backing plate need to be smaller as with my PC?............ |
Yes, it needs to be smaller than your pads. Not sure what size pads you're using, but contact (e-mail) Bob at
Danse or Patrick at
ExcelDetail and they should be able to fix you up with the size BP you need.
Edit: better yet, maybe you can can order one of these (if a 5" BP is what you need):
3M 125 mm Perfect-it III-Rotary Backing Plates - 3M Car Care and Detailing Products
We're having to pay up to $70 for one of them since that size isn't sold in the states. You'll need the one with 5/8" threads if your rotary came from the states.
