Old 06-04-08, 03:39   #1 (permalink)
alowe is offline
alowe is on a distinguished road
Why would you need a smaller pad for a DA? (N00B)
I am still getting back into the detailing world after spending my past few years overseas in the gulf.
SO,
I have a UDM with a variety of products. Mostly will be using 106ff and SIP. I have LC pads (6 in). Now, what would be the reason to use a smaller 4 in pad? For working a small area that needs help? To get into those hard to reach areas? I would imagine that is the answer, just wanted to know if I should be careful with a smaller pad, will it heat up faster, should I step the speed down when working areas?
Thanks,
Andrew
Old 06-04-08, 03:50   #2 (permalink)
bwalker25 is offline
bwalker25 is on a distinguished road
Send a message via AIM to bwalker25
Re: Why would you need a smaller pad for a DA? (N00B)
4" pads have greater correction abilities than a 6" pad, because of the smaller surface area. yes you should be careful with a smaller pad, although I dont think you would burn clear coat with a DA polisher unless you fell asleep at the wheel.
yup I use them on hard to reach areas and to achieve more correction than I could with a 6" pad.
"wet sanding BMW M3 with the terrified owner = priceless "
"3.5" PFW Pads from AG = the bomb on a PC/UDM, thanks accumulator! "
Old 06-04-08, 06:33   #3 (permalink)
wannafbody is offline
Because the orbit is smaller with the smaller pad it is more concentrated.
2000 WS6 TA NBM
Old 06-04-08, 09:55   #4 (permalink)
your speeding yellow
wascallyrabbit's Avatar
wascallyrabbit is offline
wascallyrabbit is on a distinguished road
this is what i like about 4" pads
gives more cutting power.
i only use 4"pads with my pc.
Old 06-04-08, 10:15   #5 (permalink)
I want a Mini
Banacheq's Avatar
Banacheq is offline
Banacheq is on a distinguished road
I've heard it said that the UDM counterweight is such that it's best to use 5.5" pads or smaller. Any bigger and the vibration gets to be a bit much.
I use 4" SFX pads from Autopia and 5.5" LC CCS pads. Both work great.
~Brett
Old 06-04-08, 10:18   #6 (permalink)
And there's less friction than with a larger pad, so there's less likelihood of the machine bogging down and merely "jiggling" instead of doing the full dual-action/random-orbital thing. (Credit to the other PC for originally suggesting that the *friction* is the main issue behind the bogging)
Note the the PC, for example, is really designed to move a single sheet of sandpaper, not some big, heavy foam pad wet with polish that weighs a zillion times more.
Old 06-04-08, 10:34   #7 (permalink)
that is why i'll be ordering a flex sometime in the next week. i just have to figure out what pads i'll need.
Old 06-05-08, 03:27   #8 (permalink)
Dewey, Buffet & Howe
JuneBug is offline
JuneBug is on a distinguished road
When I first bought my PC, I got the package deal from AG that included 6.5" LC pads. Now, they're ok for glazes and waxes, but they are the wrong choice for removing scratches and swirl marks. I tried the 5.5" low profile LC orange and white - man, I thought the PC was using steroids! Night and day difference - I should have listened to Accumlator from the get-go!
Old 06-05-08, 04:09   #9 (permalink)
jshillin's Avatar
jshillin is offline
jshillin is on a distinguished road
Send a message via AIM to jshillin
For the flex, get some 6" Sonus pads...
- Jason
Old 06-05-08, 06:11   #10 (permalink)
alowe is offline
Thanks fellas. I have the 6.5 CSS pads. Would you suggest the 5.5 or the 4 inch low profile for small areas for a UDM? I would also imagine I would need the 3.5" Dual Action Flexible Backing Plate?
Old 06-05-08, 09:26   #11 (permalink)
I'd use only the 4" pads for correction, large *or* small areas; the 5.5" size was never small enough to be a huge improvement over the larger ones IME. And yeah, you'll need a small backing plate.
Note the big differenced JuneBug *did* notice with the 5.5" pads...maybe that's an indication that today's pads are better than the ~5" ones that I used. Or maybe that just means that the 4" ones would *utterly* astound him
I guess the main idea is "smaller is better" and it might become a matter of degree once you get down below 6".
Old 06-05-08, 10:08   #12 (permalink)
Raz5219's Avatar
Raz5219 is offline
Raz5219 is on a distinguished road
I too noticed a big improvement with 4" pads over 6 1/2" and even 5 1/2". For waxes/Sealants and glazes, a bigger pad is fine. But for Polishing, a 4" is the only way to go on a PC IMO. You get much better correction ability and the machine is smoother and easier to control with the smaller pad. Just about everything is better with the 4" pad. Just be careful using it at Speed 6. I noticed that the smaller pad and backing plate spinning at a high RPM generated a good amount of heat. The result was my backing plate melting in the middle along with the velcro on the pad.
Rotary and 4" pads.....anyone ever use this combo? WilliamHBonney Machine Polishing 9 04-23-07 01:11
I tried a Surbuf pad bileduct Car Detailing Product Discussion 4 03-08-05 06:21
Lots of questions about Pads and backing plates..... AlexRuiz Car Detailing 11 11-05-04 03:06
Help with sonus pad usage WaterVapor Car Detailing 3 09-28-04 09:15
