05-23-08, 02:25
cjbigcog is offline
Join Date: Aug 2007 Posts: 129 | IPA Wipe Down Question After reading some of the posts regarding ipa wipe down, I'm still not clear if it's best to use 50/50, or straight ipa.
San Anselmo, Ca.
05-23-08, 03:57
| | EuroLux:. Private Detail
charlesaferg is offline
Join Date: Aug 2007 Location: Portland, OR Posts: 353 | Re: IPA Wipe Down Question Quote:
Originally Posted by cjbigcog After reading some of the posts regarding ipa wipe down, I'm still not clear if it's best to use 50/50, or straight ipa. | Personally, i use 50% Isopropyl alcohol and 50% Distilled Water.
Portland, OR - Club Flex, Metabo, Menzerna...
05-23-08, 04:04
| | DuraGloss User
AL-53 is offline
Join Date: Mar 2004 Location: Brimfield Ma Posts: 1,457 | Re: IPA Wipe Down Question Prep Sol is the better product to do wipe downs with...i find Alc/wate mix is to weak to really get all the residue..even straight seemed not to get it all..the prep sol works great...you can get it at wal mart under a different name..but the same results and product....5.89 a quart...
Al
2004 Ford Ranger FXII
Bright Red
My Pitbull rides shotgun
05-23-08, 04:08
scholar is offline
Join Date: Dec 2006 Posts: 49 | Re: IPA Wipe Down Question Al,
Prep-All is the one I got. just spray/mist on MF and wipe, right? not too wet?
have you used Prep-All at all (no pun intended)? safe? | |
05-23-08, 04:31
| | DuraGloss User
AL-53 is offline
Join Date: Mar 2004 Location: Brimfield Ma Posts: 1,457 | Re: IPA Wipe Down Question Quote:
yes I used it....I spray a little on the paint and use a dampened MF to wipe it...after a few panels its damp enough were you do not need much more than a spray on the MF and wipe...
Now DuPont has 2 types...one that does not evaporate to fast like the Prep ALL and one that flashes fast....drys in seconds..I did not like the fast drying one...
the Prep all is good stuff...cleans wax stains also...need to rub a bit though
Al
Bright Red
05-23-08, 04:33
scholar is offline
Join Date: Dec 2006 Posts: 49 | Re: IPA Wipe Down Question thanks a lot AL | |
05-23-08, 06:07
cjbigcog is offline
Join Date: Aug 2007 Posts: 129 | Re: IPA Wipe Down Question Thanks for the input! Will get some prepsol next week. Am doing a car this weekend, so will use undiluted ipa for now.
San Anselmo, Ca.
05-23-08, 08:11
jedovaty is offline
Join Date: Jul 2007 Posts: 158 | Re: IPA Wipe Down Question Quote:
Originally Posted by charlesaferg Personally, i use 50% Isopropyl alcohol and 50% Distilled Water. | So if you buy 70% or 90% IPA, do you dilute to 50/50, or just mix them 50/50 (which isn't a 50% solution). ? | |
05-24-08, 07:25
Originally Posted by jedovaty So if you buy 70% or 90% IPA, do you dilute to 50/50, or just mix them 50/50 (which isn't a 50% solution). ? | It's never going to be exactly perfect, I fill my sprayer about half with alc, then half with water. Even still, between complete fills, I usually put a bit more of either in the bottle. The dilution is still around how I like it, and if it gets too watery I add more alc.
EDIT: Forgot to mention, 91%.
05-24-08, 07:49
| | 0 to 60 in one paycheck!
SuperBee364 is offline
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,773 | Re: IPA Wipe Down Question Quote:
Originally Posted by charlesaferg Personally, i use 50% Isopropyl alcohol and 50% Distilled Water. | Me too. I use the 91% isopropyl alcohol from the pharmacy dep't at Walmart. | |
05-24-08, 07:55
Originally Posted by SuperBee364 Me too. I use the 91% isopropyl alcohol from the pharmacy dep't at Walmart. | Rgr tht.
07-01-08, 04:48
blownvert is offline
Join Date: Nov 2005 Location: MA Posts: 649 | Re: IPA Wipe Down Question what does this replace? If I wash my car and dried it, I can start polishing. What is the point of this 50/50? | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 05:40. | | | |
