Pretty sure it is aluminum Toto, thanks for the great response.
I would imagine that with metal what is used to cut and refine the finish isn't as important as the finishing steps. I was out in the garage working out a few things and trying to teach myself and came up with pretty good results.
One thing I noticed as a haze in the aluminum, even when polished, so I went back over my steps and tested on each rib of the muffler until I got the best results.
So far my best process is
Menz
PO91E (powergloss) on a wool pad at 1800 RPM x 4-5 passes to remove deeper scratches
Menz PO91E (IP) on an orange lake country pad x 2 at 1500 (using very little polish the second time)
Menz
PO85u (MicroPolish) on a lake country blue pad at 1200 rpm
Mother Mag and Aluminum polish as a finisher.
All the defects and swirls came out (as did the hazing, the finish is much deeper now) but I am wondering if a dedicated metal polish can provide better results, at least as a finish step to get maximum refinement out of the metal.
The right side is my previous best, while the left side a before.
From the results last night, even though the improvement was signifcant, it still wasn't great.
It did have a nice shine though
Much like polishing a paint and going from compound to
final polish you can still have a haze because the final polish didn't do the job correctly. So I added a middle step of IP on an orange pad and started the processes with Powergloss on the wool pad. The results where very good, but I wonder if more is left.
Here the tail pipe (the top one). It is a little harder to see the difference because the polished pipe is actually reflecting the unpolished pipe (making it appear brown).
