Autopia.org
Old 05-10-08, 02:31   #1 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
SVR has a little shameless behaviour in the past
Polishing the Pillars - new techniques
Hey everyone
This week has been R&D time in the Dream Factory and I decided to see how good my product was on these unpainted B Pillar materials
Switched from foam to foamed wool for step 1 of the 3 step non polymer system
Turns them to an almost 100% realistic glass like reflection and permanently
Redid my fibreglass unpainted spoiler again, trying to get more black out from underneath and remove the bubbly foggy finish
Foam only went so far so meg's cut n shine white wool did the trick with step 1 and foam finished off
Don't worry, the system is non abrasive, it chemically deep cleans all the coating from bottom to top and then polishes and glazes the hell out of them.
The trick with polishing unpainted moldings is to polish them by machine in the way you would polish metals - move machine from right to left to cut (or deep clean in this case) and left to right to polish
The reason for posting this is to show what can be done these days with the right technique and when going away from polymer, acrylic, silicone, wax or teflon systems
Polishing the Pillars/ Trim Dream strikes again
Old 05-10-08, 03:36   #2 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is offline
Re: Polishing the Pillars - new technique
So if they are not painted, what is that, some sort of vinyl wrap?
Grumpy like Ketch...
Old 05-10-08, 03:51   #3 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
the trims on australia's cars are urethane I think, some sort of composite materials too (fibreglass injected resin for instance)
Old 05-11-08, 01:12   #4 (permalink)
EuroLux:. Private Detail
charlesaferg's Avatar
charlesaferg is offline
charlesaferg is on a distinguished road
YouTube - Polishing the Pillars
I wouldn't be too sure about the statement "no cut." Although the product may have no cut, the friction from the pad, especially how the host of this video polishes at such aggressive angles at speed, would most definitely create enough heat to slowly remove material. Although quite minimal, it could be quite noticeable. Even more so with whatever additives are in that product.
Cool though, I've seriously got to do that on my E34!
Portland, OR - Club Flex, Metabo, Menzerna...
Old 05-11-08, 04:12   #5 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
Normally I am being very smooth with the trims that I work on, it has only been in the last few days that I have begun using wool, though not on the B Pillars, on my spoiler
Unfortunately as seen in that video, I stuffed up. It is usually dead flat on the surface and perfectly centred but looks like I didn't focus my attention enough and created some angles
The system puts a rock hard permanent sealant coating on top of them so once they are done, you never have to do them again. A forever deal.
So it is not like I'm doing that to them every six months or year
Old 05-11-08, 04:47   #6 (permalink)
fishbonezken is offline
fishbonezken is on a distinguished road
that looks fantastic SVR!
any chance of you shipping this product internationally?
if the results are truly permanent, I think it's very worth it as B-pillars with that material can get oxidized over the years with neglect, and it's hard for a dressing to restore them nicely.
Old 05-11-08, 05:56   #7 (permalink)
advs1 is offline
advs1 is on a distinguished road
2nd that!! i want some!!
Old 05-11-08, 09:35   #8 (permalink)
Really? Looks quite intentional to me. Those were some huge angles you worked in there, ha.
Yes, I'd imagine with the right product, it would stay fairly well. As stated before though, it's definitely "polishing" in the true sense of the word, leveling the surface at a mcroscopic level.
Regardless,
Looks great!
Old 05-12-08, 07:06   #9 (permalink)
"It's a possibility!"
TortoiseAWD's Avatar
TortoiseAWD is offline
Re: Polishing the Pillars - new techniques
Hey everyone
This week has been R&D time in the Dream Factory and I decided to see how good my product (emphasis mine --Tort) was on these unpainted B Pillar materials
How, exactly, is this not shilling? For your own product, no less . . . AND, you've been warned once before. Perhaps you should take a week to think about it.
Tort
(moderator)
"I used to be 'with it', but then they changed what 'it' was.
Now, what I'm with isn't 'it', and what's 'it' seems weird and scary to me."
Old 05-15-08, 09:17   #10 (permalink)
texasKA's Avatar
texasKA is offline
texasKA is on a distinguished road
what the heck is Trim Dream?
Old 05-15-08, 09:49   #11 (permalink)
Gemini13 is offline
Gemini13 is on a distinguished road
Its "his" polishing system for for trim that he pretty much shills on every board he can.
I'm not knocking the product/idea but his tactics are shameful IMO.
Old 05-15-08, 11:53   #12 (permalink)
Zet
Zet is offline
Zet is on a distinguished road
I'm sure the reason wool works better is because it is more "abrasive" than foam, so the polishing works better. I can't see why you couldn't simply use regular polishes for this? If you wan't something without abrasives KAIO on wool followed by foam would probably work well, and would seal the surface too. I might be wrong, but I fail to see why this "system" is anything special
Weekend Details - v. Prepped to Sell & Polishing Darks in Direct Sun G35stilez Click & Brag 34 05-14-06 05:31
Reviewed: Lake Country Polishing Pal G35stilez Detailing Product Discussion 12 01-17-06 09:22
Polishing Inventory - Advice Needed! chewbakarox Machine Polishing 2 07-27-05 12:09
Polishing DavidB Car Detailing 6 04-14-03 11:10
Eastwood Glass Polishing Kit Review (long) adjulian Detailing Product Discussion 3 08-25-01 11:41
