Originally Posted by SuperBee364 It does take longer to break down with a PC, but it will do the job. Speed six required. |
White pad is the least aggressive I will use for any correction with the PC, even on a very soft single stage using mild polish. Especially on harder CC paints.
The rotary uses friction to make up for it, the PC doesn't have enough, no matter how many passes you make as you're just glazing, not creating enough friction for even nano polish to break down. Remember, Nano was designed for those ceramiclear finishes, so it has extra lubricity and therefore specifically designed to give the operator a longer working time.
Originally Posted by JoshVette Don't forget to rewash it again before you apply your sealant/wax.
Menzerna uses a wax like lubricant which you'll need to remove before you apply any waxes.
Josh |
It's mineral oil and I believe glycerin as well. Best bet is to use that opportunity to apply their pure glaze, excellent stuff, and go directly to carnauba - but if you are looking to apply a sealant, I would spray the surface with IPA/wipe to prep for application.
