Autopia.org
Old 04-28-08, 04:56   #1 (permalink)
vaca222 is offline
vaca222 is on a distinguished road
Not much luck with the MF bonnets :o\
I started a thread the other day inquiring about MF bonnets for polish removal (thanks to all who replied, much appreciated!) I bought a 2nd PC to use strictly as a polish remover, thinking it would save me some time.
Eh, not so much.
I slipped the MF bonnet on over the stock foam pad that comes with the PC as well as an old 6" pad and had a hard time removing anything with it. I either had to press down really hard or barely touch the paint, and neither method provided easy and quick polish removal.
Am I doing something wrong? Maybe my speed setting was an issue (set at 3 or so)? Although I ended up being more tired my removing the polishes by hand, it seemed to be much quicker for me.
Old 04-28-08, 05:07   #2 (permalink)
From Hobby to Obsession
Denzil's Avatar
Denzil is offline
Denzil is on a distinguished road
Re: Not much luck with the MF bonnets :o\
Maybe you either...
a) overworked your polish or
b) applied too much polish to your surface
I've never used a MF bonnet before but it should be just as easy to remove polish by hand.
00 Acura Integra LS coupe
04 Yamaha YZF-R6
Old 04-28-08, 05:13   #3 (permalink)
BigAl3 is offline
use speed 5 with a mf bonnet over a cutting pad (less give/bend), or you can do it this way... YouTube - Adams Polishes: Removing the Polish (DVD Volume 5)
Old 04-28-08, 05:18   #4 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is offline
Vaca, that's been my experience, too. Difficult to remove LSP's really don't come off any better with a PC and an MF bonnet. Easily removed LSP's come off *very* fast with the PC and an MF bonnet. They'll save you some work, but unfortunately not on the hard to remove stuff. I bought them to try and help me remove HD-Cleanse (which can be the very worst product in the world to remove) with no luck.
Originally Posted by jsilver6 View Post
I can only hope that their skill level improves to match the quality of the product.
Old 04-29-08, 07:37   #5 (permalink)
Accumulator will become famous soon enoughAccumulator will become famous soon enough
With the MF bonnets, I've found *polish* removal to be more problematic than *LSP* removal.
There's more of it, it's thicker, and you generally want to get it off before it dries completely.
FWIW, I do wonder if the larger size is causing issues; I do a lot better with polish *and LSP* removal via Cyclo than via PC. It's just so easy to overload the PC with that ~6" pad, and then it merely "jiggles".
FWIW I do use higher speeds than 3 (usually ~4.5 or so) when doing such stuff with the PC.
I wonder how the Griot's polish removal system would work He's now selling a dedicated backing pad for the MF bonnets. I (like BigAl3) use a cutting pad, usually a Meg's 7006. Note that the Griot's system is specifically designed to buff off his machine polishes, and those aren't (IME) the most user-friendly polishes in the world either.
Denzil- I dunno if it's really *easier* so much as *different*. I started doing product removal via machine back when I had a shoulder injury; it was the only way I could do the job at all. The motions where simply quite different (and painless) compared to doing it by hand. I've since found that I simply like it better, and where LSPs are concerned I do believe I get a slightly better "burnishing effect" when I buff them off with the machines.
But the only polishes I buff off by machine are the 1Z consumer line stuff, which basically break down into cleaner-wax and can be allowed to dry without issues.
Old 04-29-08, 08:03   #6 (permalink)
Denzil's Avatar
Denzil is offline
Yeah, I figured that with a MF bonnet and MF towel it wouldn't be more difficult or picky with the bonnet considering they are the same material. I guess it just comes down to the motion of polish removal.
04 Yamaha YZF-R6
Cyclo Bonnets - Cyclo or AG/Cobra Bonnets chefwong Machine Polishing 10 04-19-07 05:08
PC, buffing and Buffing bonnets richydelsolsir Car Detailing 10 08-18-05 04:17
Pads & Bonnets kiaser Car Detailing 1 07-12-05 05:54
Bad Luck, Good Luck larry_bar56 Car & Driver 10 08-13-03 01:42
Best way to clean MF bonnets? Schwa72 Car Detailing 1 04-24-02 06:39
