04-27-08, 07:41
#13 (permalink)
dsms is offline
Join Date: Oct 2007 Posts: 227 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by Scottwax Absolutely. Less than 10 minutes of polishing on the *good* side.
Meguiars #105 mixed with Optimum Compound, Meguiars yellow polishing pad and 1000 rpms. Very minimal holograms, cleaned right up with 3M Ultrafina. |
You got me sold. Now I know a Makita will be worth it. I use M105 now and so far have been happy with it, never tried mixing another product with it though. Will SIP do ok to make it work longer or should I go with OC? | |
04-27-08, 07:49
#14 (permalink)
| | Resident Schizo
Mindflux is offline
Join Date: Aug 2001 Location: Austin, TX Posts: 775 | Re: Yet again, Makita 9227 of Flex 3401 RO? Hey man if you are gonna get the Makita. Coastaltool has a great deal on it, with a backing plate, two wool pads and a carrying bag for 169+ship  Not bad at all. | |
04-27-08, 07:52
#15 (permalink)
corythecarguy is offline
Join Date: Mar 2008 Posts: 5 | Re: Yet again, Makita 9227 of Flex 3401 RO? I am a firm believer in the Makita . I have been using the same Makita for over 8 years now and I have never had a problem with it . I do take it apart and clean out any polishing dust from time to time and it has never let me down . I also agree that you will never need to use it at any speed higher than 3 . I have never used a PC or any other type of non rotary polisher . I learned on a rotary and that is how I have done every polish for the last 17 years . Rotary with 3 or 4 steps of pads-polishes and then on to hand applied wax . Lately I have been thinking about getting a PC just to see what all the fuss is about .
Cory | |
04-27-08, 12:21
#16 (permalink)
jchambers is offline
Join Date: Jan 2008 Posts: 44 | Re: Yet again, Makita 9227 of Flex 3401 RO? So, seeing that I have NO experience with a rotary, you guys are still saying get the Makita over the Flex DA? And maybe get another DA of some sort later on? Would you say the rotary is THAT much faster than a flex? I am being told the flex will cut down time from the udm around 40-50%. Is this true? Thanks guys! | |
04-27-08, 01:36
#17 (permalink)
| | Proper prep is a virtue
howareb is offline
Join Date: Oct 2007 Location: Stafford, VA. Posts: 1,065 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by jchambers So, seeing that I have NO experience with a rotary, you guys are still saying get the Makita over the Flex DA? And maybe get another DA of some sort later on? Would you say the rotary is THAT much faster than a flex? I am being told the flex will cut down time from the udm around 40-50%. Is this true? Thanks guys! | If you have experience with a PC/UDM then I would say that going to a rotary is the next logical step. If it is "damage" that you are worried about, then know that the Flex can also do damge to paint. Far less likely, but it can. Each tool needs to be respected for its capabilities. A rotary, if respected, is far above any other polishing tool. Even with no experience I would get it and if you do not feel comfortable, get some practice panels. You will quickly find out that it is not as much of a bear that people make it out to be. Take it slow in the beginning. If you learn how to master wool pads then using foam will become a breeze. Stay in control of the rotary, and keep it moving. If you follow these procedures then you will not burn paint.
There are also some decent video out there on buffing with a rotary. Kevin Farrell's Buffing with confidence video (He uses a DeWalt but the priclple is the same) is a great primer for moving to the rotary. Always keeep in mind though that practice makes perfect. | |
04-27-08, 02:35
#18 (permalink)
BBS01 is offline
Join Date: Apr 2007 Posts: 30 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by jchambers So, seeing that I have NO experience with a rotary, you guys are still saying get the Makita over the Flex DA? And maybe get another DA of some sort later on? Would you say the rotary is THAT much faster than a flex? I am being told the flex will cut down time from the udm around 40-50%. Is this true? Thanks guys! | I've been using the pc for 2 years and then udm for 1 and am finally jumping ship to the rotary. The pc and udm are more than enough for what i need them for but the rotary i hear cuts polishing time in half! | |
04-29-08, 04:00
#19 (permalink)
Join Date: Jan 2008 Posts: 44 | Re: Yet again, Makita 9227 of Flex 3401 RO? Well I believe they are talking me into the Flex when ordering. It makes sense though, sense I am about to take a traveling job and will not have time to learn on panels and such, Also like he stated, most people have to go back over with a DA for a last step anyway to remove any holograms and I dont have the money for 2 machines right now. thanks for all the help guys! I still want to make the jump at some point. | |
04-29-08, 10:27
#20 (permalink)
| | Lotus Exige S
Rob Tomlin is offline
Join Date: Aug 2004 Location: Riverside, CA Posts: 945 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by howareb If you have experience with a PC/UDM then I would say that going to a rotary is the next logical step. If it is "damage" that you are worried about, then know that the Flex can also do damge to paint. Far less likely, but it can. Each tool needs to be respected for its capabilities. A rotary, if respected, is far above any other polishing tool. Even with no experience I would get it and if you do not feel comfortable, get some practice panels. You will quickly find out that it is not as much of a bear that people make it out to be. Take it slow in the beginning. If you learn how to master wool pads then using foam will become a breeze. Stay in control of the rotary, and keep it moving. If you follow these procedures then you will not burn paint.
There are also some decent video out there on buffing with a rotary. Kevin Farrell's Buffing with confidence video (He uses a DeWalt but the priclple is the same) is a great primer for moving to the rotary. Always keeep in mind though that practice makes perfect. | Other than being faster, what other benefits would a rotary have over the DA Flex (leaving price out of the equation)? | |
04-29-08, 12:26
#21 (permalink)
bert31 is offline
Join Date: Jul 2007 Location: Louisville, KY Posts: 721 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by Rob Tomlin Other than being faster, what other benefits would a rotary have over the DA Flex (leaving price out of the equation)? | Generally the finish will look more "refined" with a rotary over a DA. Not to say you can do a good job with a DA but many will argue that you can do a better job with the rotary. | |
04-29-08, 12:50
#22 (permalink)
| | 0 to 60 in one paycheck!
SuperBee364 is offline
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,020 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by bert31 Generally the finish will look more "refined" with a rotary over a DA. Not to say you can do a good job with a DA but many will argue that you can do a better job with the rotary. | There's also alot of people that say that you can't beat a DA for final finishing. I'm in the rotary camp, though. A zero-bite finishing pad on a rotary gives you the ability to reach a polish's maximum ability to jewel the finish by breaking down the abrasives in the polish to a higher degree (smaller abrasive size) than a DA can.
I pay full price for the products I use. I have never received a freebie, nor would I ever accept one.
04-29-08, 01:51
#23 (permalink)
| | Banned
WASHWAY is offline
Join Date: Apr 2008 Posts: 21 | Re: Yet again, Makita 9227 of Flex 3401 RO? Quote:
Originally Posted by corythecarguy I am a firm believer in the Makita . I have been using the same Makita for over 8 years now and I have never had a problem with it . I do take it apart and clean out any polishing dust from time to time and it has never let me down . I also agree that you will never need to use it at any speed higher than 3 . I have never used a PC or any other type of non rotary polisher . I learned on a rotary and that is how I have done every polish for the last 17 years . Rotary with 3 or 4 steps of pads-polishes and then on to hand applied wax . Lately I have been thinking about getting a PC just to see what all the fuss is about .
Cory | It is good to hear you maintain your polisher! Blow your polisher out with a blowgun before you put it away, and that will help remove the bulk of dust and polish inside. There is nothing better though than opening it up (after the warranty expires or they might use it as an excuse to void the warranty) and getting everything clean.
One thing I am surprised at is that more people don't talk about the Dewalt DW849 variable speed polisher. It is a great tool and the most widely used here in California. I get customers calling for that and the PC 7424 more than anything else.
Danny | |
04-29-08, 02:59
#24 (permalink)
| | Lotus Exige S
Originally Posted by bert31 Generally the finish will look more "refined" with a rotary over a DA. Not to say you can do a good job with a DA but many will argue that you can do a better job with the rotary. | Will the Flex DA be able to correct swirls/scratches to the same extent as a Rotary (or close)? | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 06:17. | | | |
