Autopia.org
Old 04-16-08, 04:20   #13 (permalink)
BRODEY1 is offline
BRODEY1 is on a distinguished road
Re: UDM, LLC white & FPII...now holograms, why?
Also, there were a few mentions about using KAIO on a green LLC pad, like I said, Properautocare recommended that combo...what is the consesus here about KAIO and pads?
Old 04-16-08, 09:20   #14 (permalink)
TTWAGN is offline
TTWAGN is on a distinguished road
ProperAutoCare is wrong.
Dont use the green pad with KAIO.
You are meant to go to a softer pad each process and a softer product too.
You start off with a cutting pad and a compound to remove the defects and move to a polishing pad and a polish. You then go to a finishing pad with a finishing polish as the finish gets more and more perfect. Just like sanding u start with a lower grit and finish with a fine sand paper.
You've just gone backwards and on soft paint that means marring.
If i used a green pad on my car to even apply a wax or sealant the whole car would be cloudy with marring due to the soft paint.
Old 04-16-08, 09:34   #15 (permalink)
BRODEY1 is offline
Thanks, it seemed a bit backwards when I was ordering everything, but like I said, it said it right there on the damn website...green for KAIO. Live and learn
So, I can stick with the white LLC's for Menz IP and FPII, right?
The next softest LLC pad is the black one, should I use that if I want to apply KAIO with the UDM?
So now I'm stuck with 5 green pads that I have not used....how can I best use those, which products would an Autopian use them for?
So can I now just go back over the entire car with FPII on a white pad to get the marring out?
Thanks!
Old 04-16-08, 09:37   #16 (permalink)
BRODEY1 is offline
Originally Posted by 07e90 View Post
Also isn't the LC green supposed to be more abrasive than the white? Perhaps try a black/gray pad to finish off.
By "finish off", do you mean the KAIO or the LSP (SG).
Old 04-16-08, 09:58   #17 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is offline
Yup.
Yup
I have a few of those green pads wasting valuable cupboard space, too.
That should work. If FPII doesn't work, you might have to go to a stronger finishing polish like Ultrafina or Menzerna PO106FF, but the FPII will probably work just fine for green pad induced marring. Also remember that pad induced marring can also be caused by over-working your polish. If it looks like it's starting to dry up on you, stop and re-apply if you need to keep working an area.
Thanks!
(10 char min)
Old 04-16-08, 10:06   #18 (permalink)
BRODEY1 is offline
(10 char min)
Great, exactly what I needed!
Old 04-17-08, 07:42   #19 (permalink)
TTWAGN is offline
I'd use the green pads with Menzerna IP as the green pad suits it better than the white pad.
White pad with FP11 and black pad for AIO
Old 04-19-08, 12:24   #20 (permalink)
EricDawg is offline
EricDawg is on a distinguished road
White pad with Menzerna Intensive Polish? That seems odd. Properautocare recommends at least an Orange pad for that. IP is more of an abrasive compound for removing swirls, etc., so why would you use a white pad?
Removing Swirls & Water Spots<br> in Clear Coat Finishes
I've tried that combo myself, based on the "start with the least abrasive pad first" theory. But I've never had any luck cutting away swirls with a white pad.
I have used white for water marks successfully.
And yeah... I've tried the Menzerna recommended speeds before... like the others I've never had any luck removing swirls with a PC DA at speed < 5.
Lastly - the first few times I used my PC I was a little scared, and I didn't work the polish long enough or at a high enough speed. The result was nasty haze on a black truck.
White pad and IP just seems odd to me. Maybe at a high enough speed it could some good...but I'd use Orange.
Old 04-19-08, 08:52   #21 (permalink)
Tusin is offline
Tusin is on a distinguished road
While I like ProperAutoCare and have ordered from them numerous times, they don't often have the best "advice" on their info pages.
Old 04-19-08, 09:49   #22 (permalink)
BRODEY1 is offline
[quote=Tusin;1110213]While I like ProperAutoCare and have ordered from them numerous times, they don't often have the best "advice" on their info pages.[/QUOTE
that seem to be so!!
Old 04-22-08, 06:45   #23 (permalink)
BBS01 is offline
BBS01 is on a distinguished road
BRODEY1 I am in the same boat as you! I'm running my FPII at speed 5-6 and am polishing and still get holograms. I suppose I am not breaking down the polish but how long does this take? My FPII has never "dusted" and is still slightly wet and hazy when I finish polishing. Mind you this is with 2 passes at a pretty slow pace. Is FPII supposed to dust like all other Menz products?
Old 04-22-08, 08:26   #24 (permalink)
FPII with a Flex is pretty gentle. You might be trying to get out holograms from your previous correcting step. That might be just a bit over FPII's ability. Try using a stronger polish with your finishing pad to remove the holograms, then go over it a final time with FPII.
Originally Posted by jsilver6 View Post
I can only hope that their skill level improves to match the quality of the product.
Menzerna FPII.. jedi_force Machine Polishing 10 04-22-06 04:11
Ugly white vinyl roof... Beach15 Car Detailing 12 07-31-05 06:04
FPII Pad Suggestion Smitty Car Detailing 3 06-07-05 03:22
Get white letters white again? godofthunder Car Detailing 25 07-03-03 01:42
Questions For White Car Owners…. (long) Intermezzo Car Detailing 23 02-06-03 02:11
