04-22-08, 11:39
#25 (permalink)
| | Spanish OCD
maesal is offline
Join Date: Nov 2005 Location: Valencia (Spain) Posts: 581 | Re: Metabo & Dynabrade = Ultimate detailing machine Quote:
Originally Posted by SpoiledMan I like my Dynabrade attachment. It cuts and finishes better than *any* other DA type machine that I've tried. | Better than the Flex?
I see that the finish from the rotary is much better than the one from the Flex, PC, etc... I just use the Flex for applying glazes or cleansers. | |
04-23-08, 01:04
#26 (permalink)
khakis is offline
Join Date: Aug 2006 Posts: 10 | Re: Metabo & Dynabrade = Ultimate detailing machine Nice product. | |
05-16-08, 06:14
#27 (permalink)
pampos is offline
Join Date: Oct 2007 Location: CYPRUS Posts: 848 | Re: Metabo & Dynabrade = Ultimate detailing machine i just received mine and I want to know if i can replace the plate with a smaller one of my UDM kit (5'' or 6'' or even 3.5'')or if i have to buy something familiar with the one that already attached.the UDM plates are fit but how safe they are??
Also if someone used this before what advises can give ??
__________________ I AM HERE TO LEARN!!!! | |
05-16-08, 10:21
#28 (permalink)
gbackus is offline
Join Date: Feb 2004 Location: South Gate, CA Posts: 571 | Re: Metabo & Dynabrade = Ultimate detailing machine Quote:
Originally Posted by pampos i just received mine and I want to know if i can replace the plate with a smaller one of my UDM kit (5'' or 6'' or even 3.5'')or if i have to buy something familiar with the one that already attached.the UDM plates are fit but how safe they are??
Also if someone used this before what advises can give ?? | I would not use anything smaller than a 6" or possibly a 5.75" with the dynabrade, otherwise you run the risk of severely cutting into your pads. | |
05-16-08, 11:55
#29 (permalink)
pampos is offline
Join Date: Oct 2007 Location: CYPRUS Posts: 848 | Re: Metabo & Dynabrade = Ultimate detailing machine Quote:
Originally Posted by gbackus I would not use anything smaller than a 6" or possibly a 5.75" with the dynabrade, otherwise you run the risk of severely cutting into your pads. | is it so strong??that's nice
05-16-08, 12:04
#30 (permalink)
gbackus is offline
Originally Posted by pampos is it so strong??that's nice  | Also, I wouldn't run the machine at less than 2000 RPM's, otherwise it seems unbalanced. When I had one I always ran it at 3000 RPMs. | |
05-16-08, 07:16
#31 (permalink)
pampos is offline
Originally Posted by gbackus Also, I wouldn't run the machine at less than 2000 RPM's, otherwise it seems unbalanced. When I had one I always ran it at 3000 RPMs. | This is the MAX RPM of my rotary  .With DYNABRATE attached ca i use heavier polish/compound than using with my UDM?
05-20-08, 01:44
#32 (permalink)
pampos is offline
Join Date: Oct 2007 Location: CYPRUS Posts: 848 | Re: Metabo & Dynabrade = Ultimate detailing machine i guess i have to use it like my UDM?? Working the polish at low speed and then at top speed moving the machine slowly or not?
05-20-08, 07:02
#33 (permalink)
gbackus is offline
Originally Posted by pampos i guess i have to use it like my UDM?? Working the polish at low speed and then at top speed moving the machine slowly or not? | I ALWAYS ran it at 3000 rpm, if you are limited to 2000 rpm, use that. You will get the most cut, and the nicest finish while using it at high speed. | |
05-20-08, 09:20
#34 (permalink)
pampos is offline
Originally Posted by gbackus I ALWAYS ran it at 3000 rpm, if you are limited to 2000 rpm, use that. You will get the most cut, and the nicest finish while using it at high speed. | My rotary's higher RPM are 3000....How much polish i should put one the pad??How fast i have to move the polisher??Sorry for the questions but i will use it tomorrow and i want to know...
Thanks once again for answering
05-22-08, 03:49
#35 (permalink)
gbackus is offline
Originally Posted by pampos | i'd probably use 10-20% more polish than you would normally use with a DA, but less than with the rotary.
As far as arm speed, not as fast as a rotary, not as slow as a DA, you have to really judge it for yourself. | |
05-22-08, 06:41
#36 (permalink)
pampos is offline
Originally Posted by gbackus i'd probably use 10-20% more polish than you would normally use with a DA, but less than with the rotary.
As far as arm speed, not as fast as a rotary, not as slow as a DA, you have to really judge it for yourself. | Thanks mate...
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 08:39. | | | |
