| Re: How would you guys polish this? PIC I'm not an experienced rotary user but from what I have read on here, in this case as long as the surface of the pad is flat on the surface you are polishing you should be okay.
In the second pic it looks like there are holograms there already, unless that is a reflection of clouds or something?
edit: if you have a PC, you can use it on that portion. That is what I normally do. |
