Autopia.org
Old 03-24-08, 03:45   #13 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: Rotary and smaller sections/panels
Originally Posted by Twista616
Yes and No. No matter what your using, RO or Rotary, the smaller the pad the more harmful it is. With both the RO and Rotary, its takes less force the make the 4" pad spin a full rotation. Less force = more rotations. With more rotations, the heat created is much greater because the surface area the pad touches is smaller. Its hard to explain without showing...
Give it a try on a test panel...use a 4" pad and a 6.5" pad, hold it in one spot for a certain amount of time and see how hot each one gets. The 4" will probably burn thru and be VERY hot.
sorry ...but your wrong
on a rotary 1000 RPM = 1000 RPM the force does not change the # of rotations
also the outer edge will spin about 1/2 as fast @ any given RPM then a 8" pad
less speed = less heat
Old 03-24-08, 03:55   #14 (permalink)
deathlok's Avatar
deathlok is offline
deathlok is on a distinguished road
+1 bigjimz28
you should not get confused. Rotary is a "big" tool that delivers 1000rpm=1000rpm. PC is a "small" tool it has not the power to get a 8inch pad up to work correctly so smaller pads seem to work more efficiently.
Old 03-24-08, 03:58   #15 (permalink)
Master of Redundancy
jsatek's Avatar
jsatek is offline
jsatek is on a distinguished road
I do full corrections with 5.5" and 4" pads on a Makita rotary.
If I induce any holograms, I take them right out with another pass of polish. I am starting to prefer the 4" over anything else.
Detailing Technology
Old 03-24-08, 07:20   #16 (permalink)
I want a Mini
Banacheq's Avatar
Banacheq is offline
Banacheq is on a distinguished road
What brand of 4" pads do you like the best?
~Brett
Old 03-24-08, 07:39   #17 (permalink)
Stanger'66 is offline
Stanger'66 is on a distinguished road
BigJim is right. Think back to high school/college physics. The period of one revolution is the same for each pad, no matter the pad diameter. Lets say one pad has twice the radius of another pad. The smaller pad will have half the tangental velocity of the larger pad. That is what we are concerned with in this situation, tangental velocity.
Old 03-25-08, 01:12   #18 (permalink)
jetset4me's Avatar
jetset4me is offline
jetset4me is on a distinguished road
Tangental velocity. Is that what you get when you've had too much to drink?
Club Flex
Chilling Out in Sunny SoCal
Flex 3401 vs Rotary widyhs Machine Polishing 20 12-28-07 04:50
A guide to rotary polishing Brazo Machine Polishing 41 07-05-07 09:39
First Impressions (Dynabrade DA Rotary Tool) MorBid Machine Polishing 5 05-13-06 09:31
The difference between orbital polishers and rotary buffers Mike Phillips Detailing Product Discussion 20 05-18-04 01:38
Getting "tight spots" with rotary Dude Car Detailing 6 04-20-03 08:50
