02-18-08, 07:29
newtodetailing is offline
Join Date: Jun 2007 Posts: 6 | wool pads and shedding everywhere!!!! so i bought wool pads for my makita rotary and lint goes EVERYWHERE. i've used the duo spur cleaning tool. even after my 3rd use w/ these wool pads, there's just too much lint coming off the pad. will this eventually stop? or should i just stick to foam pads? | |
02-18-08, 07:43
| | Detailing Loudoun
brwill2005 is offline
Join Date: Apr 2005 Location: Ashburn, VA Posts: 1,430 | Re: wool pads and shedding everywhere!!!! Before using them, wet your hand and rub the pad with it. Do this until the pad stops shedding.
Brad Will- Owner
Reflections Auto Salon LLC
02-19-08, 12:09
TTWAGN is offline
Join Date: Oct 2007 Location: Melbourne, Australia Posts: 239 | Re: wool pads and shedding everywhere!!!! buy some decent wool pads.
I used some yum cha pads and they were so bad.
Since then i've used meguiars wool pads and they are perfect.
Something like the edge pads are perfect too, from what ive seen. | |
02-19-08, 07:58
Join Date: Jun 2007 Posts: 6 | Re: wool pads and shedding everywhere!!!! i have the edge pads. | |
02-19-08, 08:24
smprince1 is offline
Join Date: Sep 2004 Location: Greenville, SC Posts: 1,380 | Re: wool pads and shedding everywhere!!!! I also have the Edge pads and mine shed like crazy as well. Some I've used a few times, so they've been spurred numberous times ... the shedding gets better after some use but it's still there.
If somebody has a solution I'd also appreciate hearing it. | |
02-19-08, 08:37
JonP is offline
Join Date: Feb 2008 Location: C.C. TX Posts: 309 | Re: wool pads and shedding everywhere!!!! I had this problem too. I just open the door and place a fan behind me to let it all blow out the door or do it outside. I just bought some better pads to cut down on the shedding. You might try spinning the pads on the rotary (if you have one) for a few seconds to minimize the shedding.
__________________ | |
02-19-08, 09:03
raadkins16 is offline
Join Date: Jun 2004 Location: Richmond VA Posts: 79 | Re: wool pads and shedding everywhere!!!! According to a few of the vets on here, they end up washing the car after compounding or doing corrections when using wool, so i assume the shedding and the mess never completely goes away no matter how used the pads are? | |
02-19-08, 10:12
Wren is offline
Join Date: Oct 2007 Location: The Dirty South Posts: 204 | Re: wool pads and shedding everywhere!!!! Quote: |
Originally Posted by raadkins16 According to a few of the vets on here, they end up washing the car after compounding or doing corrections when using wool, so i assume the shedding and the mess never completely goes away no matter how used the pads are? | Depends on the pad. | |
02-19-08, 03:37
wannafbody is offline
Join Date: Feb 2005 Posts: 5,582 | Re: wool pads and shedding everywhere!!!! After a few uses the shedding falls off. Try misting some QD on the pad prior to use. It is also somewhat polish dependent. Experiment with different polish and compound combo's.
2000 WS6 TA NBM
02-21-08, 03:29
| | "New Old Guy"
James Thomas is offline
Join Date: Feb 2008 Location: Saipan - C.N.M.I. U.S.A. Posts: 11 | Re: wool pads and shedding everywhere!!!! My two cents, I take a new wool pad and spur the hell out of it, run the edges on a clean corner surface of an old outside chair (not two much though) and wash them twice and tumble dry on low ( real low) before they get used the first time. This knocks the loose fibers out and "pre sheds" it so to speak. Cheap pads aren't shedding, that's controled distruction.
Even the very finest pads will shed a bit at first but then taper off in my experience.
________
James
__________________ WHO CARES WHAT I GOT OR HAD OTHER THAN MY EX AND HER LAWYER  !
02-21-08, 03:55
| | Wool is cool!
gmblack3a is offline
Join Date: Aug 2005 Location: Atlanta Posts: 4,789 | Re: wool pads and shedding everywhere!!!! Quote: |
Originally Posted by brwill2005 Before using them, wet your hand and rub the pad with it. Do this until the pad stops shedding. | I agree except I dip my hand is a bucket of water and let the new pad run on the lowest setting on the rotary. This is with the edge pads, so I do both sides. Like said a new pad is going to shed more then a used pad.
I wash the car after polishing to get rid of the dust that some polishes put off and make sure the surface is clean of polishing oils when using zaino.
Bryan Burnworth
Peachstate Detail LLC
"Paint Polishing Perfection"
Atlanta Detailing
02-21-08, 06:09
| | U Bring It - I Bling It
David Fermani is offline
Join Date: Aug 2004 Location: S. Florida Posts: 3,011 | Re: wool pads and shedding everywhere!!!! Quote: |
Originally Posted by James Thomas I take a new wool pad and spur the hell out of it.
| Right. That's what works for me also. Compressed air also helps knock off the loose fibers too.
__________________ The Perfection is in the Reflection | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 04:16. | | | |
