01-25-08, 06:20
#13 (permalink)
| | Master of Redundancy
jsatek is offline
Join Date: Mar 2006 Location: White Plains, NY Posts: 1,608 | Re: (MUST SEE) Edge adapter for Makita BO6040 Quote: |
Originally Posted by jesselyons2002 I don't know why you would need to buy a flex if you know how to use a rotary. | Good point.
__________________ Detailing Technology | |
01-25-08, 09:19
#14 (permalink)
| | Squeeky Clean
AP2TUDE is offline
Join Date: Aug 2007 Location: Southern California Posts: 163 | Re: (MUST SEE) Edge adapter for Makita BO6040 Quote: |
Originally Posted by jesselyons2002 I don't know why you would need to buy a flex if you know how to use a rotary. | I still totally agree with this. I was excited about the Flex when it first came out, but the more that I learn about its limitations with smaller pads and overall pad selection, the more that I realize I have no reason to replace my PC.
The rotary is used for 90% of all my work, and the PC suits everything else just fine. I can't understand a reason to change to a more powerful machine simply for the small areas and instances where the PC is needed.
Jonathan Edwards
ATTENTION TO DETAIL
Newport Beach, La Jolla, Montecito
01-25-08, 09:57
#15 (permalink)
| | Dewey, Buffet & Howe
JuneBug is offline
Join Date: Sep 2006 Location: Heart of North Carolina Posts: 1,624 | Re: (MUST SEE) Edge adapter for Makita BO6040 Hey, I agree. I was just stating that IF I were looking at the Makita B06040 vs the Flex - I would pick the Flex. | |
01-25-08, 03:46
#16 (permalink)
z06meister is offline
Join Date: Nov 2006 Posts: 314 | Re: (MUST SEE) Edge adapter for Makita BO6040 Quote: |
Originally Posted by jesselyons2002 I don't know why you would need to buy a flex if you know how to use a rotary. | I already have a rotary and am very proficient with it but the reason I bought the Makita BO6040 is it has close to the power of a rotary and can handle 90% of my detailing needs, about 89% more than my ROB could and it saves me a lot of time on my details since it cuts my cleanup time down to almost nothing. When I use my rotary it sling stuff everywhere but my BO6040 does not sling at all. I also don't have to wonder if I am leaving any holograms or go over it a second time with my ROB just for a piece of mind, I know it will be hologram free. I do not see the Flex as being more powerful just because it has a slightly bigger orbit and spins slower.
If anybody is in the PA/Del/NJ border area (Delaware County) and has a Flex and would like to get together and compare machine let me know. I would love to try a Flex and would be more than happy to let somebody try out the Makita with the Edge system on it. | |
01-25-08, 06:47
#17 (permalink)
admac is offline
Join Date: Nov 2001 Location: manhattan beach, california Posts: 402 | Re: (MUST SEE) Edge adapter for Makita BO6040 not to be dense, but where did you order that adapter? | |
01-25-08, 07:09
#18 (permalink)
wannafbody is offline
Join Date: Feb 2005 Posts: 5,580 | Re: (MUST SEE) Edge adapter for Makita BO6040 google EDGE, Autogeek probably can get it too.
2000 WS6 TA NBM
01-29-08, 04:28
#19 (permalink)
Originally Posted by wannafbody google EDGE, Autogeek probably can get it too. | Yes, Autogeek will be selling them. | |
02-01-08, 03:45
#20 (permalink)
DJBAILEY is offline
Join Date: Jul 2006 Location: Apex, NC Posts: 219 | Re: (MUST SEE) Edge adapter for Makita BO6040 The Makita B06040 has true dual-action. With almost double the power of the PC the spinning doesn't stop when you apply pressure to the pad like the PC does making it single-action really. The vibrations are significantly lower compared to the PC also. I bought it because I wanted a better ROB than the PC, plus you get to switch it to forced-rotation mode. You get a choice of 2 modes. The Flex is a true DA machine also but only has 1 mode doesn't it? I keep the 3.5" backing plate on the PC now for doing small or tight areas.
I did buy the super-soft backing plate for the BO6040 which made it work better in the forced rotation mode. The EDGE adaptor looks good but but all my pads are the regular type. Anyone know if there is an adaptor out there so that we could use regular 6, 5 and 3.5" backing plates meant for the PC? | |
02-01-08, 04:06
#21 (permalink)
| | KnuckleBuckett
KnuckleBuckett is offline
Join Date: Apr 2007 Location: PA, USA Posts: 823 | Re: (MUST SEE) Edge adapter for Makita BO6040 Just throwing this out there...
EDGE just came out with a much more conveniet quick change adapter for the PC. Much stronger (like that is even required?) than the current version and alot easier to work the release.
Here is a YouTube clip from them about it. YouTube - New Edge 2000 Industrial Adapter
That said I wish the EDGE folks would get to work and get us a Flex adapter!!!!! C'MON!!! Guys, I know its a pain, but you always came through for us in the past, don't fail us now!!!
02-01-08, 06:14
#22 (permalink)
rwisejr is offline
Join Date: Feb 2007 Location: LI NY Posts: 357 | Re: (MUST SEE) Edge adapter for Makita BO6040 Quote: |
That said I wish the EDGE folks would get to work and get us a Flex adapter!!!!! C'MON!!! Guys, I know its a pain, but you always came through for us in the past, don't fail us now!!! |
I don't think they made it for the PC only the rotary.I have one and love it !!!!Much easier design.I never had a problem with the old ones but this is much easier to release the pads.
Ron
Club FLEX Member, Club Rotary Member Club Systemone Member | |
02-01-08, 11:05
#23 (permalink)
The Edge is offline
Join Date: Jan 2007 Posts: 52 | Re: (MUST SEE) Edge adapter for Makita BO6040 Quote: |
That said I wish the EDGE folks would get to work and get us a Flex adapter!!!!! C'MON!!! Guys, I know its a pain, but you always came through for us in the past, don't fail us now!!! | Have Faith and Patience my young Flex-I warrior! We are always watching what the customer wants and are always innovating and adapting to the market. These things take time to perfect and develop but rest assured we are working on it! Keep posted!
Aaron
02-01-08, 11:40
#24 (permalink)
DJ_JonnyV is offline
Join Date: Sep 2007 Location: St. Louis Posts: 312 | Re: (MUST SEE) Edge adapter for Makita BO6040 Nice, look at that!!! That's promising to see as I have some Edge pads that I used with my PC that have been sitting idle since the Flex showed up last September.
Club FLEX | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 09:17. | | | |
