Old 12-28-07, 03:17   #1 (permalink)
bert31's Avatar
bert31 is offline
bert31 is on a distinguished road
Going from Hyper Com to Opt Polish.
My car has very hard paint - white paint. Last fall I polished my car with an orange 5 inch CCS pad and Optimum Compound. OC did a pretty decent job on the swirling by using two passes but still some swirling. My paint was so hard, it finished LSP ready. I went ahead and followed it with Poli-Seal but Poli-Seal really did nothing appearance wise to the paint, only put down a base for my sealant.
Next spring I will polish again with Hyper Compound and a yellow 5 inch CCS pad. Will following that combo with Optimum Polish on a white 5 inch CCS pad be too much of a jump? In other words, will the hazing left over from Hyper Compound and and the yellow pad be too much for Optimum Polish on the white pad? Should I take a smaller step down to Optimum Compound on an orange pad THEN go to Optimum Polish on a white pad?
Thanks for any help you can provide.
Old 12-28-07, 03:22   #2 (permalink)
toyotaguy's Avatar
toyotaguy is online now
Re: Going from Hyper Com to Opt Polish.
hyper on orange pad, then op on white should do the trick...yellow might marr too much
take a small bottle of a mix of hyper and OP and you essentially created the same cut as OC...
Old 12-28-07, 03:26   #3 (permalink)
bert31's Avatar
bert31 is offline
Yellow might marr too much that Optimum Polish would not be able to clean up after it?
Old 12-28-07, 03:27   #4 (permalink)
wannafbody is offline
On orange OC might finish fine enough.
2000 WS6 TA NBM
Old 12-28-07, 04:11   #5 (permalink)
toyotaguy's Avatar
he mentioned that combo wasnt enough for him...
yellow is an aggressive cutting pad that will mar in most cases...only way for me to tell you yes or no is to actually do it...I cant tell you it will or not...try it out....
Old 12-29-07, 08:40   #6 (permalink)
bert31's Avatar
bert31 is offline
Is hyper really that much more aggressive than OC? I assumed I would need to go up one in pad aggressiveness also. I will give it a try next spring.
Old 12-29-07, 09:57   #7 (permalink)
SShine is offline
SShine is on a distinguished road
Ive never had a problem with yellow pads marring regardless of the product used *shrug*
FS/FT: MF towels/applicators, XMT 180, Hyper Dressing, Pro Polish, SSR 1, Clay Msoph12 Good Deals 4 07-30-07 07:32
Autoglym Glass Polish Lynn Phillips Detailing Articles & Videos 0 11-20-06 05:50
Should polish removal be this tough? rx280 Machine Polishing 1 11-12-05 03:10
AIO, PB PWC, AutoGlym SRP, OPT polish with green pad. opass Car Detailing Product Discussion 6 11-01-05 11:03
Z wax application directions given YoSteve Car Detailing 6 04-16-02 03:38
