12-27-07, 11:51
David Strum
weekendwarrior is offline
Rotary Pads
I just got a new Makita rotary, and am debating which pads to buy. I have the 5" and 6" backing plate, and currently have several of the 6.5" Meguiar's pads, as well as a few of the 6.5" CCS pads. I am wanting to buy some 7.5" pads (would prefer to not go any larger than that), and have been looking at the 7.5" CCS pads, as well as some of the Edge pads. Any recommendation on which 7.5", or maybe 8" foam pads are the best to go with?
12-27-07, 12:26
toyotaguy is offline
Re: Rotary Pads
i hear the curved LC pads work really well on the rotary
*now offering PDR, window tinting, bumper repair and repaint!*
12-27-07, 01:13
RCBuddha is offline
Re: Rotary Pads
Stick with the 6" pads, the larger pads are harder to control.
Proud Member of:
Club HITACHI, PC, Cyclo & MENZERNA
12-27-07, 01:23
David Strum
Re: Rotary Pads
Which brand? I notice the CCS 6.5" pads seem to only mention DA use, not rotary.
12-27-07, 01:29
RCBuddha is offline
Re: Rotary Pads
I use Excel Propel (now Erasure). I'm sure someone else will chime in on the Lake Country offerings.
Proud Member of:
12-27-07, 01:31
wannafbody is offline
Re: Rotary Pads
2000 WS6 TA NBM
12-27-07, 01:37
1981 Camaro Z28
BigJimZ28 is offline
Re: Rotary Pads
pads are pads!
use the pads you have
12-27-07, 01:38
David Strum
Re: Rotary Pads
So...
There is no problem using these pads with the rotary, even though the PC is the only machine referenced?
CCS 6.5 inch foam pads, Lake country ccs foam pads, porter cable pads, ccs polishing pads, ccs pads
Just looking for clarification (sorry for the stupid questions)
12-27-07, 01:47
Re: Rotary Pads
nope, no problem...you can use the 4" pads on the rotary as well, with the correct backing plate...it just matters what is most comfortable to you...those are the pads you should be using!!!
12-27-07, 01:51
David Strum
Re: Rotary Pads
Thanks - My PC is set up for 6.5" pads, so I would prefer to buy the same size, and be able to use them all for either machine.
Thanks for everyone's help - I guess I will go take advantage of the 20% off sale at Autogeek.
12-27-07, 02:00
RCBuddha is offline
Re: Rotary Pads
Thanks - My PC is set up for 6.5" pads, so I would prefer to buy the same size, and be able to use them all for either machine..
Yup, I have multiple pad sizes, but if you can simplfy your pads to one size, it will be easier to switch b/w the two machines.
Proud Member of:
12-27-07, 02:04
Re: Rotary Pads
What backing plate do you have? Does it have a centering button? If so the CMA pads I mentioned have a center hole in the velcro for perfect centering.
2000 WS6 TA NBM
