Having used all brands of pads the best on the market are definitely the
meguiars solo pads.
Wool pads are much better on a rotary in my opinion when it comes to swirl removal. They are softer so they are flatter on the surface and are less likely to produce holograms than a similar cut foam pad.
They are also much smaller than your normal 8inch rotary pad so they are easier to control.
Wool pads are without a doubt the best pad to use on a rotary when it comes to removing imperfections.
The solo foam pads are very good for finnishing as well. They seem to easier to control than the Edge and
lake country pads.
