Results 1 to 4 of 4
Thread: MEG Pads
  1. #1
    MEG Pads
    Nuke33's Avatar
    Join Date
    May 2006
    Posts
    425
    How are meg pads i got some lc pads but i figure next ones i get i will get localy and they have meg the have a ton of 3m stuff autobody supplyer but there all rotary pads!
  2. #2
    Re: MEG Pads
    Eliot Ness's Avatar
    Join Date
    Aug 2004
    Location
    Lexington, KY
    Posts
    3,404
    I have some of the Meg's polish (8006) and finish (9006) pads that I like about as well as any other pad I've got.
    The burgundy cutting pad (7006) is not recommended by Meg's to use with the PC because of the hazing it can leave behind. Some members have reported using it w/o problems (followed up with a less aggressive pad /polish). I don’t have a 7006 so I can't say if it's any more aggressive than a typical yellow cutting pad or not.
  3. #3
    Re: MEG Pads
    Dave KG's Avatar
    Join Date
    Jun 2006
    Location
    Dundee, Bonnie Scotland
    Posts
    1,154
    On the rotary, Meguiars pads arealways the pads that I reach for - they are simply supberb on rotary polishers.
    On the PC they also work very effectively, and I have had no issues using the W7006 burgandy cutting pad on the PC, espeically if followed by a finishing polish on there polishing pad as mentioned above...
    One thing is that the megs pads require a 5" backing plate. A 6" backing plate is too wide for the velcro backing, and can cut into the back of the foam, espiecially on the softer W8006 and W9006 pads and destroy the pad.
    "A thing of beauty is a joy for ever: Its loveliness increases; it will never pass into nothingness; .... "
  4. #4
    Re: MEG Pads
    Join Date
    Feb 2005
    Posts
    7,011
    The megs burgundy pad is now softer than the older ones. The yellow is nice by RO but a bit soft.
    2000 WS6 TA NBM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
