Results 1 to 3 of 3
  1. #1
    PC 7336SP ---Just purchased ...what else now? :-)
    Join Date
    Aug 2006
    Posts
    4
    Just bought myself a present. A PC 7336SP.
    What do I need to buy from here?
    I'm completely new to this.
    I have a BLACK 97 Acura now where the paint is faded beyond belief and has webbing of the paint and even after hand claying it and waxing, still is crazy dull.
    What backing plates/polishing pads/cutting pads? Also, what products should I buy for this application?
    Thanks!!!
  2. #2
    Re: PC 7336SP ---Just purchased ...what else now? :-)
    Join Date
    Aug 2006
    Posts
    4
    Thinking Meguiars #4 heavy cut to start...then move on to what? Also, what pads do I use for each applicaiton?
  3. #3
    diamondgraphite's Avatar
    Join Date
    Dec 2006
    Posts
    19
    I use a 5" backing plate w/ either 6.5 or 7.5 pads, not sure if its better to use a 6" backing plate w/ 7.5" pads? I would recommend Menzerna Power Gloss via orange cutting pad, (recommending power gloss over intensive polish since you said you have heavy scratching/ oxidization) , Menzerna Final polish via white polishing pad, Menzerna Final touch glaze via black glazing pad, then Menzerna FMJ (polymer sealant) via red pad or by hand. This regimen should make your car look 100x better. I'm sure others on here can recommend what theyve used w/ great results as well.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
