Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Pad repair?
  1. #1
    Pad repair?
    Join Date
    Feb 2004
    Location
    cali
    Posts
    215
    I managed to get the velco backing piece of my yellow cutting pad from detailersparadise to seperate from the pad itself. The white stuff the backing pad adheres to just tore away from the pad when I was polishing at speed 6. Do you think I can reattach it? The pad is in fine shape otherwise, maybe some liberally applied 3m spray adhesive to the velco part and then push it back down on that pad. Could this have any negative side effects other than not working?
  2. #2
    audipower's Avatar
    Join Date
    Jul 2004
    Location
    Ashtabula
    Posts
    502
    no, i would of suggested that. It's not going to hit the car.
    Long Live My Audi. She Will Dearly Be missed.
    Visit My Gallery if you wish!
  3. #3
    audio1der's Avatar
    Join Date
    Feb 2003
    Location
    Calgary, AB
    Posts
    485
    I don't know if spray adhesive will be strong enough, although I can't think of a better option- please let us know how it works out!
    '01 Sentra SE 5spd P/P, mods.
    Nicely cared for, driven hard.
  4. #4
    Join Date
    Feb 2004
    Location
    cali
    Posts
    215
    well im gonna order some new propel pads as well, but if i can revive this one then i will definitely give it a shot. sucks too because IMO the yellow cutting pad from DP has the best design because the contact are to the backing plate is not raised up and therefore didnt tear the pad at all, just came un glued. probably from washing them i would guess, i think i clean the pads up too much
  5. #5
    Join Date
    Jul 2004
    Location
    Rosedale, Queens, NY
    Posts
    1,747
    I had the same problem with my Sonus DAS pads. I tore off the white velcro padding from my green pad, and the orange pad's white pad started separating after one use!!!
    I may need to try another manufacturer of pads. Good luck with your fix, and let us know how it turns out.
    '02 CAMARO SS SOM; 5.7L LS1/FLS6B
    '08 TBSS AWD Black Granite Metallic
  6. #6
    Alfisti's Avatar
    Join Date
    Jul 2004
    Location
    Perth, Western Australia
    Posts
    3,298
    Images
    4
    Please don't take this as a criticism to anyone, but when velcro designed for a PC separates, I think of two reasons:
    1) More frequently, too much pressure applied at too high speed.
    2) Less common, pad defect.
    I've used Sonus DAS pads professionally for some time without failures. I was tutoring a fellow Autopian on PC usage and could see the way he was using the Sonus pads, he'd be shedding the velcro if he didn't back off the downward pressure.
    Just a friendly word of advice from an ol' fella.
    Paul Marmarinos
    Flawless Prestige Detailing
  7. #7
    Join Date
    Feb 2004
    Location
    cali
    Posts
    215
    haha, i have no doubt its user error in my case, still very much a noob.
  8. #8
    Join Date
    Jul 2004
    Location
    Posts
    1,747
    Only the orange and green pads (the green pad after the third use) separated. The blue pad stayed put on all of the other jobs. I don't recall putting pressure on the machine, as I took care in noting how to apply the pc. In fact, I remember a couple of instances where I wanted to put on more pressure, but I refrained from doing it. Each pad I'd say were used for 45 to 70 minutes per stage, on average. I could be inclined to believe the duration of the polish job at the higher speeds may have been too much for the pads, but I worked up gradually from speed two to five and then six.
    I don't believe it was hand pressure in my case, but there is always room for learning at any experience level. I may switch brands in any event and see whether the same thing happens.
  9. #9
    Tasty's Avatar
    Join Date
    Mar 2005
    Location
    The Lone Star State
    Posts
    1,588
    I say this all the time, but this is the reason I don't use speed 6 on the PC.
    "I can't believe that we would lie in our graves wondering if we had spent our living days well." - Dave Matthews
  10. #10
    Join Date
    Jul 2004
    Location
    Posts
    1,747
    On the babe (car#1) I went to five, but on the daily driver I went to six. I did see a polishing improvement with the higher speed, but there was more energy on the machine's part in the process.
  11. #11
    Join Date
    Feb 2004
    Location
    cali
    Posts
    215
    well i went ahead and used some 3m aerosol adhesive spray to put the thing back together. I am letting it dry overnight and I will see how it holds up to some PC action and my new bottle of DACP tomorrow. wish me luck, cuz im broke lol
  12. #12
    Alfisti's Avatar
    Join Date
    Jul 2004
    Location
    Posts
    3,298
    Images
    4
    Yeah, I keep away from speed 6 unless I'm using the SFX pads which have a bullet-proof velcro.
    I find that if the pad shape distorts at 6, then it's too high...I drop it to 5.
    Also, the wider the pad, the more pad distortion. So I try and use the smaller sizes at those high speeds, i.e., SFX, Megs 6 1/2", LC VC 6" pads. The DAS pads are 7".
    Paul Marmarinos
Posting Permissions
  • You may not post replies
  • You may not edit your posts
