Results 1 to 11 of 11
  1. #1
    What SSR with what propel pad and what detail steps??
    Join Date
    Jun 2005
    Posts
    107
    I have some medium to light swirls and marks I would like to remove from one of my vehicles. Im pretty much set on the propel pads(unless someone has a reason why not) and some poor boys. I was thinking some SSR2 should do it but what pad should I use with it. Also after I use the SSR2 should I step down to a the SSR1 with a lighter pad. Then move onto my Zaino Z-5 and Z-2pro??? I need help im new to all this. Should I be adding some steps?? Recommendations please. Thanks Chris
  2. #2
    J.J.'s Avatar
    Join Date
    Mar 2005
    Location
    OH
    Posts
    1,141
    Basic process is as follows:
    1. Wash
    2. Clay
    3. Polish with your SSRs. I would use SSR 2.5 the SSR 1
    4. LSP
    Depending on the swirl severity, use either the green or orange pad witth the SSR 2.5/2 and then the green pad again with the SSR 1. If your swrils aren't too bad, you may be able to go straight from 2.5 with a green pad directly to LSP. Look for micromarring to determine if this is plausible.
    JJ
    MZ3 Hatch Zoom - Zoom
  3. #3
    Join Date
    Jun 2005
    Posts
    8
    I just used SSR 2.5 with a green propel pads last weekend on my explorer, sounds like a similiar condition to your car, it worked really well. This was my first time using my PC, amazing what it can do. Followed up with SSR 1 on a blu pad and you are good to go.
  4. #4
    Join Date
    Jun 2005
    Posts
    107
    I went out this morning and took a really good look at the car. Its more like medium plus marring (that spiderweb effect?) with a light swirl. Would this require a SSR 2.5 or a 2???? Oh for the newbie here what is LSP? Thanks Chris
  5. #5
    J.J.'s Avatar
    Join Date
    Mar 2005
    Location
    OH
    Posts
    1,141
    I would always buy the 2.5. It is a better swirl remover with excellent breakdown properties. I have plenty of SSR 2, PM me if interested. LSP = Last Step Products, Zaino in your case
    JJ
  6. #6
    White95Max's Avatar
    Join Date
    Jan 2004
    Location
    Stevens Point, WI
    Posts
    6,909
    Try a small area with SSR2. If it doesn't work to your satisfaction, use SSR2.5. Simple as that.
    Paul...
    '03 Mazda Protege5 5spd, sunlight silver - AIO/UPP/Nattys
  7. #7
    Join Date
    Jun 2005
    Posts
    107
    For applying the Zaino with the PC would I use the Blue pad or the Grey pad. I want to buy a few extra of those since i will be using those the most. Im assuming the Blue's, the grey seem like they are for super light milky polishes/waxes/selants. How many vehicles do you think one pad will last. 10 or more??
  8. #8
    White95Max's Avatar
    Join Date
    Jan 2004
    Location
    Stevens Point, WI
    Posts
    6,909
    One finishing pad (grey) will last a long time. The polishing/cutting pads are put through a lot of abuse on speed 6 and with applied pressure and such, so they will not last as long. Finishing pads rarely take any pressure and I always use mine on speed 2-3 when applying waxes/sealants so they still look/work like new.
    Paul...
  9. #9
    Join Date
    Jun 2005
    Posts
    107
    so does one pad sample kit (one of each pad) plus 2 blue and 1 green extra sound good? Would I use the grey or the blue to put the zaino z2pro on or the z5?? Chris
  10. #10
    J.J.'s Avatar
    Join Date
    Mar 2005
    Location
    OH
    Posts
    1,141
    Green is the go- to pad for most in the propel line. I use grey pads for paste wax and blue pads for liquid waxes/ sealants like EX and EX-P.
    JJ
  11. #11
    White95Max's Avatar
    Join Date
    Jan 2004
    Location
    Stevens Point, WI
    Posts
    6,909
    Yeah that's probably adequate, unless you plan to detail for others as well. If that's the case you may want 2 yellow pads, since it's nice to have 2 clean pads for a detail. It's nicer than having to clean a pad full of oxidation and use it again.
    Paul...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
