Page 2 of 2 FirstFirst 12
Results 13 to 17 of 17
  1. #13
    holland_patrick's Avatar
    Join Date
    Nov 2004
    Location
    hartford ct
    Posts
    1,485
    I'm getting my pad's today in hours I hope i'll tell you how they fit/look
  2. #14
    Join Date
    Aug 2004
    Location
    wisconsin
    Posts
    198
    Autogeek does sell LC 7.5 inch pads
    Eric Dunn
    Lake Country Mfg
    Sales/Tech Support
  3. #15
    MattZ28's Avatar
    Join Date
    Apr 2004
    Location
    Palm City, FL
    Posts
    1,397
    '96 Camaro Z28 LT1/4L60E
  4. #16
    Mmmph's Avatar
    Join Date
    Jun 2002
    Location
    N. Cackalacky
    Posts
    495
    Ooops...I really need to stop splitting my pills...
    My car is cleaner than yours!
  5. #17
    maesal's Avatar
    Join Date
    Nov 2005
    Location
    Valencia (Spain)
    Posts
    623
    Quote: Originally Posted by BookemDano
    I use the CMA LC Pads. The CMA pads are "Constant Pressure" pads. They have a second layer of blue foam that "...acts as a cushion or shock absorber between the machine, the operator and the surface being worked on. It absorbs off-axis motion while maintaining a constant and uniform pressure on the surface."
    Here's a link that explains "Constant Pressure" (towards the bottom):
    http://www.properautocare.com/mafopaloatla.html
    Here's a link about the 7.5" Constant Pressure pads:
    http://www.properautocare.com/ad712inhipa.html
    And Here's a link for the 7.5" pad kit with flexible backing plate ("7424-ADV Kit"):
    http://www.properautocare.com/ad712inhipad.html
    Make sure that you include a "FBP-6DA" for your PC and and a "FBP-6C" for your rotary. You can order one of the kits that includes one of these pads. Here's a link showing the PC backing plates (including the "FBP-6DA"):
    http://www.properautocare.com/flbaplfordup.html
    And finally, here's a link showing the rotary backing plates (including the "FBP-6C"):
    http://www.properautocare.com/flbaplforcip.html
    Good luck on your decision.
    Regards,
    Dan.
    Can you tell me your experience with this PADs via PC?
    I read that this ones:
    http://www.properautocare.com/hi612infopaa.html
    are the best for using LC PADs vÃ*a PC, and I must include the 6" plate. Do you know how much will be the shipping to Spain?
    Thanks.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
