Page 12 of 17 FirstFirst 1234567891011121314151617 LastLast
Results 133 to 144 of 196
Like Tree177Likes
Thread: UPDATE!! Current Dual Action Polisher Comparison - Garry Dean - Tampa, FL
  1. #133
    Re: UPDATE!! Current Dual Action Polisher Comparison - Garry Dean - Tampa, FL
    C. Charles Hahn's Avatar
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,626
    Quote: Originally Posted by Kevin Brown
    I have several G100's G110's, and G110v2's in my arsenal. There is no doubt that over the years, the Meguiar's machines have a wide variance in regards to top speed. Just last night, a great customer of mine called to ask what speed I recommended for sanding with Abranet Soft. I happened to have discs, machines, and test panels right in front of me, so I asked for a couple minutes, and I'd call right back. The first G110v2 (an old but sturdy prototype unit) works perfectly at speed 2.0. Just to be certain, though, I pulled out my brand new G110v2 (just arrived from Meguiar's two days prior). That machine required speed 4.25, and I didn't necessarily need the added OPM, but that setting was required to get me ample backing plate rotation (about 1 turn per second).
    Just goes to show... we're all trying to be very specific in terms of speed settings and power capability, but if every other machine varies in terms of speed & power (within a particular manufacturer's offering), it's no wonder why we're all confused as to why our machine works perfectly, yet the next guy's machine seems to be subpar.
    OK... well I guess the next best question to ask would be this: is there an ideal OPM/RPM speed for the execution of sanding tasks that can be quantified? And if so, is there a way to measure how fast one's given machine is actually running at a given setting on the speed dial/level of applied pressure? I know there are optical tachometers for measuring RPM, but I'm not sure if they would also work to check actual OPM output.
    Meguiar's states a speed of 4800 OPM for the D300/MF Cutting disc setup, they must have been able to determine that figure through some sort of process.
    Although some guys have come around to using equal-diameter backing plates (where the backing plate is the same or very close to the same diameter as the buffing pad), most haven't had the opportunity to try this type of set-up. What becomes immediately apparent is how much "brake action" is created by the section of the pad that isn't being supported when using an undersized backing plate. It's a BIG deal, and the rotation is so much better with the full diameter plate, that you can actually drop the speed of the machine, and get the same rotation. It also will not bog as rapidly. I sell a few types, and need to add a couple more to the site. Xact-Fit Backing Plates
    If you don't want to spend the dough to buy a plate, or you'd rather not cut a larger plate to size... simply cut down a microfiber disc or foam pad to the same size as the plate you've got on hand. Keep in mind that you'll be using a lot of surface area (so the pad will load with paint residue more rapidly, and you'll automatically see more rotation because the pad is smaller in diameter).
    I have all three of your Xact-Fit plates, and they do make a big difference in terms of cut. The video clip I posted was made before then, though, just using a standard W67DA with the 5" MF disc.
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  2. #134
    Join Date
    May 2011
    Location
    San Jose, CA
    Posts
    103
    Used my HD Polisher today, noise really wasn't that much worse than my G110. Was fine using no ear plugs or headphones.
    Another good video as always tho
    www.californiasfinestdetailsupply.com
    Full line of 3D/HD Products & Nanoskin Pad/Towel/Mitt
  3. #135
    Join Date
    Dec 2005
    Location
    Texas
    Posts
    345
    I recently purchased the Griot and a bunch of pads. It does a terrific job of cleaning my shower and my hot tub. However, I will not use it or any other electric polisher on my car. I know everyone swears by them and in the hands of someone like Gary or other pros they do work magic. But I just bought a 2012 brand new Mercedes in Diamond White (an expensive paint option) and having never used a polisher before it scares the heck out of me. This paint will never need correction. I've seen all the videos and read all the "how to" articles and it looks like a piece of cake, however, my experience with trying the polisher on the hot tub taught me that these things are too powerful and can get out of control too easy to put on this kind of paint. I guess I'll have to continue to do my polishing and sealing by hand.
  4. #136
    Dan
    Dan is offline
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,967
    You paint, even from the factory can use polishing. If the dealer touched the car, for sure. I get a kick out of people saying how great their car looks with wax x or y. Nothing beats a car finished out with something like PO85rd. If you do it right, the looks are unreal, the paint looks like its going to drip down onto the pavement.
  5. #137
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,626
    Quote: Originally Posted by RZJZA80 View Post
    I always thought the whole point of using a DA/RO was that it DID stop spinning when the edge of the pad touched something, on corners, edges, and uneven surfaces, as to prevent burning. Isn't this the whole point of using a DA/RO over a rotary? Forced rotation is always something I don't get the concept of, why not just use a rotary then? I think a DA/RO SHOULD stop stop spinning if enough pressure is placed upon it, but in real world terms, that much pressure will never be used, no it's really not applicable. I think it's more important that a polisher doesn't heat up backing plates, or otherwise just break, rather than hey it can still spin even if you stand on it. If a PC and any other DA/RO can use the exact same products and get the job done in exactly the same number of passes, then that extra power doesn't mean anything, OPM's are OPM's. Otherwise, if the PC does take longer, the power does play a larger role. I say this because so many are still using the PC and are happy with it.
    Not exactly, no.
    The point of using a DA is that it does not instill buffer swirls like a rotary can. The safety factor of lower RPM and stalling under pressure is just a side effect. Just like a rotary, the rotation is what makes cutting/correction possible.
    While the PC can be effective, the reason the extra power does matter is that the other machines can generate more of the centripetal force that spins the pad and keep the pad spinning with higher rotating masses and/or produce more rotation for faster cutting.
    Charlie
  6. #138
    Thomas Dekany's Avatar
    Join Date
    May 2004
    Location
    Portland Oregon
    Posts
    11,241
    Kevin, I have always been a big fan of using that type of a setup. I agree, the difference is big.
    Wow, and I thought I was really into machines... I'd have much more sinister or self-serving plans for that wish!
    I didn't get the same impression using the Griot's AT ALL. But, this goes to the point I just mentioned.
    Again, machine variances.
    NO AFFILIATION WITH "any" COMPANY http://www.tdekany.com
  7. #139
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,626
    I get that, but if a PC and GG6 both spin at 6000 OPM, isn't that the main factor? It's still spinning at the same speed, so the GG6 has a more powerful motor which causes it to stop spinning with more applied pressure, but is OPM not OPM across the board? In other words, what makes the GG6's 6000 OPM's so much more "powerful" than the PC's at 6000 OPM's?
    The difference is that one of the elements of proper technique does involve a degree of pressure, and a more powerful machine can maintain its speed under pressure better than a weaker unit.
    Charlie
  8. #140
    Forum Sponsor
    Kevin Brown's Avatar
    Join Date
    Jun 2004
    Location
    Santa Maria, CA
    Posts
    625
    Images
    31
    It's not just the amount of "power" a motor provides, either. There's other aspects to consider; maximum RPM (claimed RPM is not always accurate... I've verified as much as a 20% variance); gear ratio (where the motor shaft transitions to the counterbalance/spindle assembly); "tightness" of the bearings used to support the assembly; overall moving mass (low mass gets to speed more rapidly, but can slow more readily under load); quality of the balancing mechanism (if the machine is teeter-tottering, the motion could scrub rotation ore readily); stroke diameter (all other things being equal, large stroke machines create more centripetal force).
    There's probably some other things I haven't thought of while writing this.
    As an example of "big power" isn't the only thing to consider... my 3/16" stroke Mirka CEROS machine (schematic here) creates an incredible amount of rotation. It's got a diminutive motor (although it is a very efficient brushless design). Pretty sure its got a gearing box, too, but I haven't busted the machine open to verify this). The machine tops out at 10,000 RPM, which is ridiculously high for polishing purposes.
    Paint polishing is a learned craft, not an art form.
    Realizing this is the most important step one can make towards becoming a better paint polisher!
  9. #141
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,626
    One of the many reasons the Dynabrade mounted on my DWP849X is such a monster.
    I assume that's no-load RPM, correct?
    Charlie
  10. #142
    Forum Sponsor
    Join Date
    Jun 2004
    Location
    Santa Maria, CA
    Posts
    625
    Images
    31
    I think so...just like the rest of the machines. Otherwise, they'd have to go through a battery of testing parameters, stating the diameter & type of pad or disc, the pressure, which material it was tested on, wet or dry, which compound or polish, etc.
  11. #143
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,626
    Right, gotcha.
    Well, I just broke down and ordered an HD Polisher; I'll be very interested to see how it compares to my Meguiars DAs.
    Leadfootluke and Garry Dean like this.
    Charlie
  12. #144
    Join Date
    Dec 2008
    Posts
    256
    Right, gotcha.
    If you get one that spins, it's a beast!
  1. HD Polisher Video Review - Garry Dean - Tampa, FL - Premium Custom Detailing
    By Garry Dean in forum 3D / High Definition Car Care
    Last Post: 03-02-13, 02:46
  2. Dual Action Polisher Comparison Video - Garry Dean - Tampa, FL
    By Garry Dean in forum Machine Polishing & Sanding
    Last Post: 07-10-12, 02:38
  3. Replies: 11
    Last Post: 06-06-12, 01:46
  4. 1999 Kawasaki Vulcan Classic detail - Garry Dean - Tampa, FL
    By Garry Dean in forum Motorcycle, Marine & RV Detailing
    Last Post: 05-23-12, 06:40
  5. Replies: 17
    Last Post: 05-10-12, 05:57
Posting Permissions
  • You may not post replies
  • You may not edit your posts
