Page 4 of 5 FirstFirst 12345 LastLast
Results 37 to 48 of 59
Like Tree1Likes
Thread: Griot's Garage 6" Polisher: Current state of affairs
  1. #37
    Re: Griot's Garage 6" Polisher: Current state of affairs
    Thomas Dekany's Avatar
    Join Date
    May 2004
    Location
    Portland Oregon
    Posts
    11,151
    Interesting how we had threads about keeping the GG pc at 4, the Meg's at speed 5 and the PCXP at 6 soon after the first MF pads came out to prevent damages with the pads. Either people forget or don't do research.
  2. #38
    Registered
    Join Date
    Jun 2007
    Posts
    810
    I've read where users go with speeds > 5 on GG6 and MF pads, so apparently it's not a universal rule. Megs I never tried, and my PC I haven't used in a few years.
  3. #39
    Join Date
    May 2007
    Location
    Southwestern PA
    Posts
    1,073
    I believe the Lifetime Warranty offered with the GG DA is important for those of us who don't detail as a profession. Consider that a hobbyist might use the unit 5 or 6 times per year and that if the machine should fail after a few years it can simply be returned for repair or replacement. Without the lifetime warranty we would have a significant repair charge or worse have to purchase a new polisher.
    Regarding the heat build up--I applied a coat of HD Speed to my Passat's hard paint--6 passes at speed 6 with firm pressure and 2 passes with light pressure using a B&S Orange pad to remove light to moderate wash induced marring. I used two sets of two pads--after each couple of sections I'd clean the pad on the fly with a denture brush then replace it with another--switching back and forth between the two for half the car and the same with the second set of two for the other half. NO heat build up problems what so ever. (Perhaps I should have used MF pads, UNO or Polish but this was my first complete polish--so with experience I may change my technique.)
  4. #40
    Join Date
    May 2004
    Location
    Portland Oregon
    Posts
    11,151
    It is not a "RULE" but some of us figured out pretty quickly that higher speeds meant melted pads. Again one needs to use common sense. If D300 recommends to use that speed ( I recall) with the MF pads we are on our own if the pads get damaged. MF or foam. As pwaug also suggested, use 1 pad for 1 panel and switch to another if you need to use higher speeds. With speed 5 ( I use it often on some paint) the pads will last longer, but not like when you use 4.5
  5. #41
    Barry Theal's Avatar
    Join Date
    Aug 2008
    Location
    Pennsylvania
    Posts
    3,919
    Blog Entries
    1
    Quote: Originally Posted by DJ Mayo View Post
    Speed 6 is just a waste, even though the added pressure slows down the rotation, your not loosing the cut. The movement of the DA provides the cut, while you want the pad spinning some, it does not need to spin at full speed in order to get what you want. This past week we did a test with 15lbs of pressure on speed 4.5 and 30lbs of pressure on speed 4.5 / not only did the 30lbs of pressure cut more, it provided a slightly better finish too since the pad wasn't spinning freely.
    How does one measure exact pounds of pressure?
  6. #42
    DJ Mayo's Avatar
    Join Date
    Apr 2007
    Location
    Northern Va and Va Beach
    Posts
    1,731
    a digital scale that is used for measuring weight for when shipping packages. You can take whatever machine you are using are measure the weight and get a feel for how much pressure is being added, etc.
    DJ Mayo
    Paint Correction Specialist
    Northern, Va
    Detailed Image Mid-Atlantic Featured Detailer
  7. #43
    Join Date
    May 2011
    Posts
    232
    by attaching a transducer to the da which in turn will measure mechanical pressure which is then converted into an electrical signal that can be metered by a pc and displayed by a graphing program on the pc.
  8. #44
    Registered
    Join Date
    Jun 2007
    Posts
    810
    So what does common sense have to do with it? Some people get great results with > 5 speed, and others just don't. My only statement was that it's not a universal rule that 4-4.5 is the only way to use MF pads.
  9. #45
    mikenap's Avatar
    Join Date
    May 2009
    Location
    Charlotte/LKN, NC
    Posts
    1,470
    Actually, 4800 OPM is the universal "recommendation" from Meguiars when using their pads and compounds. It says it on the bottle of D300. Anything outside of that, and you're flying solo.
    Mike Napoli
    CMC Detailing
    Serving Charlotte, Concord and Lake Norman, NC
  10. #46
    Registered
    Join Date
    Jun 2007
    Posts
    810
    Yes, I realize and already know what is "recommended", but I said it's apparently not a "universal rule", in other words, if you don't follow the recommendations, you may still be just fine, even though you're on your own. "Universal rule" being the key point in my statement, nothing about what's recommended and what's not.
  11. #47
    mikenap's Avatar
    Join Date
    May 2009
    Location
    Charlotte/LKN, NC
    Posts
    1,470
    I understand, and am clarifying not just for you but for anyone else reading this thread. Thanks. Relax, I'm not attacking you!
    Mike Napoli
    CMC Detailing
  12. #48
    Registered
    Join Date
    Jun 2007
    Posts
    810
    Hey my bad, I've gotten a little defensive since certain people try to discredit whatever I say... haha! It's all good though, we're here to learn and help others when possible.
  1. Griot's Garage 6" RO polisher or Meguiar's DA polisher for a beginner?
    By xradman in forum Machine Polishing & Sanding
    Last Post: 01-18-12, 12:45
  2. Griot's 3" Random Orbital Polisher
    By gdumond in forum Professional Detailer General Discussion
    Last Post: 02-13-10, 06:20
Posting Permissions
  • You may not post replies
  • You may not edit your posts
