Page 3 of 5 FirstFirst 12345 LastLast
Results 25 to 36 of 59
Like Tree1Likes
Thread: Griot's Garage 6" Polisher: Current state of affairs
  1. #25
    Re: Griot's Garage 6" Polisher: Current state of affairs
    Registered
    Join Date
    Jun 2007
    Posts
    810
    Actually, I had an older "pro" GG6 that the backing plate would not come off, i sent it back simply asking them to remove the plate, but they sent me a brand new one, without the "pro" on there. I'm sure they could have removed the backing plate, even if the spindle was damaged, it had to have been cheaper than an entire unit. Now I'm thinking if one goes in for warranty, they may keep the "pro" ones and just send the newer ones to cover themselves a bit better. That's just the conspiracy theorist in me talking though.
  2. #26
    Paul Sparks's Avatar
    Join Date
    Aug 2006
    Location
    Indianapolis
    Posts
    1,076
    I exchanged one about 5-6 months ago and got another marked PRO on it. Did that at their warehouse here in Plainfield In.
    Paul Sparks
    Distinctive Auto Detailing
    Indianapolis IN 46234
    http://www.facebook.com/pages/Distin...70659146390192
  3. #27
    D&D Auto Detail's Avatar
    Join Date
    Mar 2005
    Location
    Northern VA
    Posts
    1,557
    Given the same car, same paint, same backing plate, same pad, speed, technique, etc. How could one DA machine leave pigtails and another DA machine not? Assuming specifications are the same.
    RaskyR1 likes this.
  4. #28
    brownbob06's Avatar
    Join Date
    Mar 2012
    Location
    NW Ohio
    Posts
    232
    I can't use my GG6 on speed 6 for more than one pass without it getting extremely hot. To the point that I feel it will ruin my backing plate or pad. ( I've had it ruin my backing plate on speed 5 and pads at 4.5 and 5.)
    The machine works great as long as you pull it off the car very often to check for heat, but it's a PITA that I can't keep working longer than 10-15 seconds without it getting super hot.
  5. #29
    LeMarque's Avatar
    Join Date
    Aug 2011
    Location
    New Mexico
    Posts
    261
    I recently experienced a similar situation as RZJZA80. I was using the GG on speed five with Optimum MF pads and the pad came apart. Truth be said, I started to prime another pad and it separated from the foam. My supplier is replacing all the Optimum MF pads for me ( purchased about a dozen) with Optimums latest iteration.
    I also experienced an LC H2O Tangerine beginning to fail, the backing plate seemed to cut a circle in the foam; again speed 5.
    This is the replacement GG I just received and it's acting a bit funny. At first it would sound as if speed would change on it's own, then it seemed like it wasn't spinning the pad!?
    I'm going to be using it today to see if whether it's user error or not.
    Bought it as a backup to my Megs DA and I'm beginning to feel like I wish I knew HD was going to be shipping before I purchased it.
    “Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves.”
    ~Albert Einstein
  6. #30
    DJ Mayo's Avatar
    Join Date
    Apr 2007
    Location
    Northern Va and Va Beach
    Posts
    1,731
    Honestly, you don't even need speed 6 on the GG DA EVER! For compounding stages with say MF pads, I stay at 4.5 all the time with roughly 25-30lbs of pressure. I use to use speed 6 from time to time 18months ago, but since then with 4.5, I have not ruined a single pad from heat. The correct pressure is where you get the cut from. If speed 4.5 doesn't cut for you, try a little more pressure and make another pass.
    DJ Mayo
    Paint Correction Specialist
    Northern, Va
    Detailed Image Mid-Atlantic Featured Detailer
  7. #31
    Registered
    Join Date
    Jun 2007
    Posts
    810
    I'm glad this thread has found others having a similar problem, and it wasn't just me lol. Keep the suggestions coming, as it will obviously help many people here to achieve better results.
  8. #32
    Dan
    Dan is online now
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,894
    Whoa, DJ is back! What difference have you found with a lower speed and more pressure vs speed 6 and less pressure? I really don't apply any pressure to the tool, other than its own weight. I find it slows the rotation of the tool and I don't seem to get any better results with more weight, at least not the same way as a rotary. I could certainly see the 30lbs and speed 6 creating some serious heat.
  9. #33
    RaskyR1's Avatar
    Join Date
    Jan 2009
    Location
    Shakopee, MN
    Posts
    2,927
    Holly cow! Who's this guy?
    I have to agree with DJ. I'm on speed 4-4.5 for pretty much every car I do and I never go over speed 5.
  10. #34
    DJ Mayo's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    1,731
    Speed 6 is just a waste, even though the added pressure slows down the rotation, your not loosing the cut. The movement of the DA provides the cut, while you want the pad spinning some, it does not need to spin at full speed in order to get what you want. This past week we did a test with 15lbs of pressure on speed 4.5 and 30lbs of pressure on speed 4.5 / not only did the 30lbs of pressure cut more, it provided a slightly better finish too since the pad wasn't spinning freely.
    DJ Mayo
    Northern, Va
  11. #35
    Dan
    Dan is online now
    Dan's Avatar
    Join Date
    Aug 2006
    Location
    NoVA
    Posts
    5,894
    Thanks DJ. I'll give it a go at a lower speed and more pressure and see what sort of results I get.
  12. #36
    DJ Mayo's Avatar
    Join Date
    Apr 2007
    Location
    Posts
    1,731
    Sounds good, let me know.
    DJ Mayo
    Northern, Va
  1. Griot's Garage 6" RO polisher or Meguiar's DA polisher for a beginner?
    By xradman in forum Machine Polishing & Sanding
    Last Post: 01-18-12, 12:45
  2. Griot's 3" Random Orbital Polisher
    By gdumond in forum Professional Detailer General Discussion
    Last Post: 02-13-10, 06:20
Posting Permissions
  • You may not post replies
  • You may not edit your posts
